'74 carburetor - NCRS Discussion Boards
'74 carburetor
  • John D.
    • December 1, 1979
    • 5507
    '74 carburetor
    I got a phone call today with the following question. An individual is looking for an original restored carburetor for her 74. Small block 350 with an automatic trans. I know absolutely nothing about this subject but will try and help this lady.
    Where do I go from here gang?
    Thanks, John
  • Dick W.
    • 10483
    Re: '74 carburetor
    Sell her a fuel infestation unit JD. I am sure you can BS you way through that
    Dick Whittington
      • 11692
      Re: '74 carburetor
      Have her check with Custom Rebuilt Carbs in New Jersey, or Mark Smith of OEM Carbs in Texas. Both are easy to find on the web.
        • 43279
        Re: '74 carburetor
        Thanks, John
        John-------
        The carb she needs depends upon whether the car is an L-48 or L-82 and it depends upon whether it's an original California-delivered car or not. The engine suffix code will answer these questions.
        • John D.
          • December 1, 1979
          • 5507
          Re: '74 carburetor
          Thanks Doc Patrick and Joe. Will get back to her for more info.
          My job is to locate the carburetor for her. I get a lot of calls like this and do my best to appease everyone even though on this call I am in over the head.
          John
            • 43279
            Re: '74 carburetor
            John
            John------
            Right now, I can tell you this: just about any of these 1974 carbs are hard to find. The L-48 carbs were used on limited applications besides Corvette. The L-82 carbs were Corvette-only.
            To make matters worse, these 1974 carbs were part of engine assemblies that had all sorts of driveability problems. The carburetors were often "hashed up" in a vain attempt to make the engine run better.
              • 6956
              Re: '74 carburetor
              John, found this on Flea bay. This might work, looks for sure like its a rebuild. eBay item number:301089287515
              • Edward M.
                • November 1, 1985
                • 1922
                Re: '74 carburetor
                John, like Joe said, need to know if the car is L-48 or L-82, and is or is not California Emissions. The engine suffix code would tell us all we need to know. This carb http://www.ebay.com/itm/Rochester-Qu...51ed5b&vxp=mtr has a date code of E4 (May, 1974). Good luck on your search.
                • Michael W.
                  • April 1, 1997
                  • 4290
                  Re: '74 carburetor
                  I don't show 7044202 as being a Corvette carb in my references.
                  • Edward M.
                    • November 1, 1985
                    • 1922
                    Re: '74 carburetor
                    Mike is absolutely right. That is what I get for trying to do things from memory.
                    OK, here is what I got from the Black book for 350, auto cars
                    L-48, automatic - 7044206
                    L-82, automatic - 7044210
                    L-82, automatic, Calif emissions - 7044506
                    Hopefully this info is accurate. Good luck on your search.
                    • Todd L.
                      • August 26, 2008
                      • 298
                      Re: '74 carburetor
                      I show 9 different carbs it could be. I finally found one for my 74 LS4 with 4spd from carb junky's http://www.carbjunkys.biz/
                      Once you find the specifics it will be much easier to narrow it down for you.
                      • Edward M.
                        • November 1, 1985
                        • 1922
                        Re: '74 carburetor
                        7044206, 7 different date codes http://www.google.com/url?sa=t&rct=j...,d.eW0&cad=rja
                        • John D.
                          • December 1, 1979
                          • 5507
                          Re: '74 carburetor
                          Thanks men. I asked for more info but have no gotten a reply. I may just list to Doc Patrick and give the lady the names of the two carb guys. I didn't realize there were so many carbs for a '74. Thanks for all the help. If she gets back to me I will jump back on here. Much appreciated, JD
