1960 engine pad stamping - NCRS Discussion Boards
  • Lynn L.
    1953-55 Team Leader
    • February 1, 2000
    • 162
    Were engine stamp pads ever machined (rotary ground) and restamped at the factory assembly time?
  • Joe M.
    • April 30, 1990
    • 1338
    Re: 1960 engine pad stamping
    Have you checked the archives? I believe this topic has been discussed in the past.
      • 43247
      Lynn------
      The answer is yes.
      • Michael W.
        • April 1, 1997
        • 4290
        Most rotary grinding operations would require removal of the head to allow access to the surface by the tool. Never heard of such a thing. Simple identification errors on the stamp pad were corrected with a hand held burr grinder which crudely removed the old info. Engines with this type are referred to as 'grind outs'.
          • 43247
          Mike and Lynn------
          I may have misunderstood the original question. I thought Lynn was referring to a grind-out using a hand held (rotary) grinder. That's the only type of grind-out I've ever seen and that's what I was referring to.
          • Michael W.
            • April 1, 1997
            • 4290
            This question is somewhat ambiguous. I thought maybe a milling machine as used in engine shops to deck a block was being discussed.
            • John D.
              • June 30, 1991
              • 875
              When we toured Flint engine plant in 1991 they showed how they did it with a 4" disc grinder.....
              • Lynn L.
                1953-55 Team Leader
                • February 1, 2000
                • 162
                file://localhost/Users/maryellenlibby/Desktop/DSCN1042.JPG
