C2 vent window adjustment - NCRS Discussion Boards
  • Randy S.
    • January 1, 2003
    • 586
    Guys,
    Just finished rebuilding the vent window regulator on my 66 convertible. Gears are tight but the issue I' m now having is the vent window doesn't "nest" or sit correctly in the weather strip pocket. I have to push the top of the vent wing forward just slightly ( about 1/32") to get it to seat correctly in the gasket. I can see the upper pin (hinge) on the vent window frame is worn. The vent window is tight on the regulator. The hinge pin is tight except for the final 1/4" travel before seating then it is loose.
    If I can remove the vent window, can the hinge pin be shimmed with some thin sheet metal stock? Other repair methods??
    Randy
  • Donald O.
    • May 31, 1990
    • 1591
    Re: C2 vent window adjustment
    which is worn too far? the pin or the hole?
    • Randy S.
      • January 1, 2003
      • 586
      Don,
      I don't know as I was not able to get the vent window out. I was pressing down on vent window as described in shop manual but it would not move enough. I may live with it if it is a complex or expensive fix, car is just a driver. I had the bolt out that holds the vent window but does the regulator need to come out too?
      Randy
      • Randy S.
        • January 1, 2003
        • 586
        So I get everything all back together including door panel. I am admiring my work and I notice the vent glass will now slide out of the vent window frame.
        Looks like I need that fabric material , vent window glass mounting material, Paragon Part #3495.
        Is this an adhesive material or a press fit? Any tips on installation?
        Randy
          Randy
          Randy -
          Commonly called "glass setting tape" - available at any auto glass repair shop.
