1956 to 1962 Windshield Frame Disassembly and Assembly Procedure - Online - NCRS Discussion Boards
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11363
    Re: 1956 to 1962 Windshield Frame Disassembly and Assembly Procedure - Online
    Originally posted by Jill Jahn (59140)
    Thanks Rich. Still working on my dashpad. Installed the Corvette insert and grab bar along with the speaker screen and the gauge cluster today. Still need to cut/install the defrost bezels Afterwards I think I'll be ready to glue it down in the front near the cowl. As a side note, one thing we did when installing the Corvette insert, is we took a round plastic lid from an oatmeal container and cut it in half and used each half as the 'protective guard for the sharp ends of the insert preventing any cuts or tears to the vinyl. Once we were done getting the insert secured in the back,we pulled out the plastic lid halves. It worked like a charm.
    Question...once the top is glued down near the cowl, do I need to trim the bottom of the dashpad (this is the part that is the vinyl overhang). Does it need to be glued down as well? Or does it fit behind the trim pieces?
    Another question...on my windshield weatherstrip, we have dry fitted it to the bottom trim of the windshield. It appears that the middle screw holes don't quite line up, causing the weatherstripping to have an excess of rubber between the middle screw and the next screw. Is this common or are we going about this incorrectly? Should we place the weatherstripping in the channel on the car near the cowl vent and then install the Windshield?
    Here are a few pictures of my progress this weekend.
    Any advice you can provide will be helpful. Thanks Rich.
    Jill, 59140
    Jill,
    Good idea with the plastic lids. Those edges of the insert are very sharp.
    Glue....... No need for glue anywhere below the pad under the dash as the trim above radio/heater plate and the fiberglass heater cover will hold those areas in place. None near the kick panels or under the instrument cluster either. The flap on the drivers side may be a little short to be covered by the high horizontal area of the kick panel near the dash end cap. All AK pads are a tad short there. You may have to slightly heat and stretch that area for the kick panel to cover it, but I've never been able to cover all of that flap. (edit see pg 50 lower photo of the dashpad pdf for a typical result. It's the area apx the height of the green arrow in the photo. pg 51 lower right photo shows the passenger side and you can see how the flap fits better)
    Weatherstrip under the windshield...... Seems like the holes were not punched properly. I think it'll be fine once the weight of the assembly lays it flat down on the dash. Remember to put som caulking around each hole in the dash for the T-bolts. Or you could repunch the holes for better alignment and fill the wrong holes with black strip caulking. I wouldn't recommend putting the rubber down on the dash first. It'll wiggle around as you're trying to set the assembly.
    Rich
    P.S. Since we've been also talking a lot about the dashpad here, for future reference I'm including this link to that procedure for any future readers.
    https://www.forums.ncrs.org/attachme...6&d=1499166287
    • Daniel S.
      • July 25, 2017
      • 117
      Hi
      Thanks for the instructions I am working on my 60 windshield now and was wondering about how to do it. this will really help.
      Dan
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11363
        #18
        Dan, Glad you got it. As you progress feel free to create a new thread with any questions regarding your specific task.
        Rich
