A-6 Compressor clutch removal? - NCRS Discussion Boards
  • Tom L.
    • October 17, 2006
    • 1439
    Does anyone have a tutorial for the process to remove and replace a clutch on an A-6 Compressor (Pics). Didn't see anything in the service manual. Thanks!!
  • Dick W.
    • 10483
    Re: A-6 Compressor clutch removal?
    You need a clutch puller and installation tool. Should be able to find them on fleabay
    Dick Whittington
    • Wayne M.
      • March 1, 1980
      • 6414
      Here's the tool for remove/install. The high quality supplier is "Robinair", if you're searching.
      This pic being brought to you courtesy of Photobucket, as I (and others ?) are having difficulty attaching pics using the "manage attachments" button below. The IT group (Gary Chesnut) and I are trying to work through this issue, with partial success, as I just discovered.
      T
        • 15616
        Wayne,
        Don't mix up the distributor parts with the AC parts.
        Tom,
        Chose your poison:
        http://www.amazon.com/s/ref=nb_sb_no...ressor%20tools
        If you want the gold class tools haunt evilBay for Kent Moore tools. The back of each section of the Chassis Overhaul Manual should have the J-xxxx numbers for all the tools. Put those numbers into your search for list on the bay and just look at your email each morning. Easy Peasy.
        • Dick W.
          • 10483
          T
          And it helps to have the brass feeler guage to set the clutch up when reassembling
          Dick Whittington
          • Dick W.
            • 10483
            Wayne,
            Tom,
            Chose your poison:
            http://www.amazon.com/s/ref=nb_sb_no...mpressor tools
            Don't discount the Robinaire tools. I have both Kent Moore and Robinaire. Quality is equal
            Dick Whittington
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11334
              I found this one years ago when I rebuilt the A6 on the wife's car....
              And this is a full repair tutorial written by a fine technical contributor over at corvetteforum......
              http://forums.corvetteforum.com/c1-a...placement.html
              • Tom L.
                • October 17, 2006
                • 1439
                Thanks for all the insight, seems I'll be shopping for some tools. I'm doing this not because I have a known leak but the compressor I have has a two groove pulley. I have another compressor with the correct puley and I want to swap them. Replacing the shaft seal is a no brainer at this point but one other concern. Are the compressor body seals typically a probelm? I don't know the history of either compressor that I have but do know they have not been in service for quite some time. Thanks!!
                • Richard M.
                  Super Moderator
                  • August 31, 1988
                  • 11334
                  Tom I've rebuilt a few A6's front ends, and never had a problem with internals or other seals. They're pretty bulletproof, except for those darn front seals spittin' oil out after the felt wick gets saturated.
                  edit add......but I always use new o-rings/seals on the rear manifold.
                  • Mike G.
                    • January 1, 1991
                    • 418
                    Tom: I also wondered about the front/rear head O-rings and both my A/C guys strongly recommended replacing them. They harden up and when the case is up to pressure -you get leakage.When I removed them, they were hard as a rock and triangular in shape. Glad I went to the effort.PM me about the Kent-Moore tools shown in the service manual. I have the full set, including the long-reach snap ring pliers and vise-mounted holding fixture.Mike
                      • 15616
                      I agree with Dick. I just posted Amazon's offerings because it was the low hanging fruit.
                      • Tom L.
                        • October 17, 2006
                        • 1439
                        Relpied w/ PM
