1966 distributor ID question - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2587
    I have a 66 L-79 which is supposed to have the 1111156 distributor; however, the ID band is missing. Is there any other way to identify the distributor?
    I've been searching to see if there is anything that identified the 156 versus the 153 or any other distributor. I know that if the vacuum can is original I should the 236, but I don't think it is original.
    Don Harris
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • Gene M.
    • April 1, 1985
    • 4233
    Re: 1966 distributor ID question
    Don, look at the advance "football" cam for the centrifugal advance. A normal style shaped "football" cam is the one for L79. You all ready know the vacuum can to look for. It should have the cast in tach drive, cast iron housing.
      Don Harris
      Don -
      All '63-'74 carbureted Corvettes used the same distributor housing - only the mix of tuning parts (mainshaft with "football", weights & springs, point cam plate, and vacuum advance) determined what part number band went on it at Delco-Remy. None of those tuning parts are visible as-installed except the vacuum advance.
      • David L.
        • July 31, 1980
        • 3310
        Don,
        My 1111153 distributor dated "6 A 10" (Jan. 10, 1966) has a cam stamped "532" & "CCW", a shaft with the "football" stamped "208W", and 1881371 weights. The vacuum control on my 1111153 distributor is stamped "MS", "357", and "20" but I believe that the correct vacuum control is GM # 1115355.
        The photo below is of a tracing of a 1881371 weight.
        According to my 1967 Chev. Parts Catalog (Apr. 1967) the shaft listed for distributors 1111153 and 1111156 is GM # 1967241. The cam for distributors 1111109, 1111112, 1111141, 1111153, and 1111156 is GM # 1966994. The weight spring part number for 66-67 Corvettes (327)(exc. T.Ign.) is listed as 1951743. The vacuum control listed for the 1111156 distributor is GM # 1116236.
        Dave
          • 15706
          For '66 and '67 I believe the only difference between the 300 and 350 HP distributor was the VAC - 236, 8" for L-79 and 355-12" for base 300 HP. They both had the same centrifugal curves according to AMA specs.
          The 236 is really too aggressive for the L-79 since it idles at 14-15". A 12" VAC meets the Two-Inch Rule.
          Similarly the 355 is okay for a 300HP/automatic that idles at lower speed/vacuum in Drive than a manual in neutral. A 15" VAC meets the Two-Inch Rule for a manual idling in neutral.
          A too aggressive VAC can cause part throttle detonation if fuel octane is marginal.
          • David L.
            • July 31, 1980
            • 3310
            Duke,
            What you you mean by the "Two-inch Rule"?
            1116236 (stamped "MS", "236", "16")
            1115355 (stamped "MS, "355", "15")
            Dave
            • Donald H.
              • November 2, 2009
              • 2587
              Gentlemen, thanks.
              Don Harris
                • 15706
                Originally posted by David Liukkonen (3775)
                Duke,
                Dave
                It's been explained here a zillion times. May I suggest using the search function?
                Or you can find it here:
                • David L.
                  • July 31, 1980
                  • 3310
                  Don,
                  I came across these two photos while looking thru my files. They might be helpful.
                  Dave
