Threaded tape for vacuum hose connections used at factory on a 69 - NCRS Discussion Boards
  • Gary H.
    • June 8, 2008
    • 308
    Whats the best way to get the treaded tape look at the vacuum hose connections for a c3? My originals are long gone.
    • 6956
    Re: Threaded tape for vacuum hose connections used at factory on a 69
    Gary, i used 3m electrical friction tape from home depot. its really a cloth type tape.
    • Gary H.
      • June 8, 2008
      • 308
      Where does the tape need to be? I know at the center tree between the headlights...anywhere else?
        • 15632
        For 1969 & 1970 it is found at the filter right off the intake and at the T at the drivers side drain gutter just outboard of the master cylinder and a lot of other places I can't remember.
          • 6956
          Gary, I believe there are a few places I think the AIM may show you those places, and the engine type may vary where the tape is placed.
          • John C.
            • January 1, 2005
            • 616
            Gary
            The vacuum hose tape on a 69 will be similar to packaging tape. It is a clear tape that will yellow with age. The cloth tape started in 1971 if I remember correctly.
            John
            • Pat M.
              • April 1, 2006
              • 1582
              Ed, are you speaking of the black cloth tape that helps hold the vacuum hoses themselves (not the connectors) in a bundle? If I understand the OP the tape he's taking about is a clear plastic tape with "threads" in it.
              Terry in this previous thread you confirmed with a picture that your 70 originally had tape around the washer check valves as well: https://www.forums.ncrs.org/showthre...e+vacuum+hoses
              This thread has some good general tape photos as well:
              https://www.forums.ncrs.org/showthre...=threaded+tape
                • 6956
                Pat, There is clear /white filament tape in a few spots maybe that is what he referring to. the filter on intake and headlamp area to.
                • Gary H.
                  • June 8, 2008
                  • 308
                  Thanks for the links. I was talking about the clear tape.
                  • Bill L.
                    • February 1, 2004
                    • 1403
                    I found 3M clear tape with threads that was identical to the tape on my 70 other than width. I cut it down and only thing now i sit is too new and not so yellow and dry.
                    Bill
                      • 43279
                      Bill
                      Bill and Gary-----
                      Yes, I agree. The 3M reinforced packaging tape is identical to the original tape. Very easy to find in your local office supply store. You won't need very much of the roll for the vacuum hose connections. You can use the rest for packaging. It's great for that, too.
                      • Gary H.
                        • June 8, 2008
                        • 308
                        What is the width of the original tape?
                        • Bill L.
                          • February 1, 2004
                          • 1403
                          See pic below and above.
                          Not mine but may be from another NCRS member.
                          Vacuum Valve w:Tape.jpg
