58 leaf springs 340E8 date - NCRS Discussion Boards
  • Brandon T.
    • October 23, 2008
    • 872
    Can anybody tell me what 340E8 stands for on the bottom leaf spring? I would think E is for June and the 8 is for 58 but not sure what the 340 stands for.
  • Philip C.
    • December 1, 1984
    • 1117
    Re: 58 leaf springs 340E8 date
    Hi Brandon E= for Eaton the manufacture, 340= day of the year, 8= year made. Phil 8063
    • Brandon T.
      • October 23, 2008
      • 872
      Phillip, if 340 is the day of the year they would not be correct for my july 16th build date, is that correct?
      • Philip C.
        • December 1, 1984
        • 1117
        Brandon I would say a Jan Feb ... 59. Phil 8063
        • Brandon T.
          • October 23, 2008
          • 872
          Thanks Phillip, I was looking at these springs on ebay hoping they would be correct for my July 58 car. I don't guess I will not bid on them.
            You can't see the date as-installed - it's covered by by the spring/shock retainer plate.
            • Brandon T.
              • October 23, 2008
              • 872
              John, would you look at the leaf springs that is listed on ebay. One of them are bent on the end, just want your opinion to see if you think it can be straightened.
                Brandon -
                Got a link?
                • Brandon T.
                  • October 23, 2008
                  • 872
                  I'm not sure how to send you a link but the item number on ebay is 201011532222
                    Brandon -
                    I think a good spring shop could correct that - will require disassembly, heat, repair, and anneal.
                    • Brandon T.
                      • October 23, 2008
                      • 872
                      Thanks John, do you have any idea what Eaton would charge to restore a set of springs.
                      • Gary C.
                        Administrator
                        • October 1, 1982
                        • 17940
                        Brandon,
                        Make sure the "340E8" is under the spring shackle plate. Sometimes, no often, but sometimes the stampings are outside of the plate area and can be seen during judging.
                        Gary
                        NCRS Texas Chapter
                        https://www.ncrstexas.org/
                          Nope, not offhand - call Mike Eaton at (313) 963-3839 and ask.
