Rustoleum paint - NCRS Discussion Boards
Rustoleum paint
  • John D.
    • December 1, 1979
    • 5507
    Rustoleum paint
    My helper found a rattle can paint that is unbelievable. Rustoleum Automotive Black Gloss. Also comes semi gloss, etc.
    Don't pour the paint on. Just dust it and see the magic results. Flows out to show condition. Try it. JD
  • Philip P.
    • February 28, 2011
    • 558
    Re: Rustoleum paint
    I agree also their professional in a quart can is very good and the shine is pretty spot on.
    Phil
    • Fred Y.
      • April 30, 2000
      • 319
      Re: Rustoleum paint
      They "WERE" also making a right -on semi-flat up until a couple yrs. ago. Unfortunately , with the VOC laws the formula was changed.
      • Jerry W.
        • January 27, 2009
        • 588
        Re: Rustoleum paint
        great stuff...Rustoleum Automotive Black Gloss....used it 35 years ago on a body on frame to preserve it perfectly until we did the body-off resto 2 yrs ago
        • Domenic T.
          • January 29, 2010
          • 2452
          Re: Rustoleum paint
          John,
          Absolutly right, thats all I use on the A/C compressors I do. It does great on brackets and every thing else under the hood. I will say that it only does well out of the sun's rays. I used it on exposed parts and it oxidized. It holds it's selected gloss under the hood forever.
          I am using Rustoliums engine enamel also with great results. Also their redish brown primer is great under the paint as it reduces the amount needed to get coverage. I have used the primer under engine enamel for years and heat does not effect it.
          DOM
          • Larry E.
            • 1700
            Re: Rustoleum paint
            Not sure what is happening to No.: 7777 Rustoleum. This is "Satan Black". Getting harder to find now and wonder if the formula has
            changed. This is a very popular paint with the restorers I know. Anybody know about this?? Larry
            Larry
            LT1 in a 1LE -- One of 134
            • Fred Y.
              • April 30, 2000
              • 319
              Re: Rustoleum paint
              It changed for sure---Luckily , I ordered 3 cases before it did---should be a lifetime supply----
                • 11697
                Re: Rustoleum paint
                If it was "Satan Black" I'd change the name and formula too if I were them. I'd probably make it Satin Black, but that's just me.
                • Donald O.
                  • May 31, 1990
                  • 1593
                  Re: Rustoleum paint
                  Oh you PC types from the west coast
                  of MI.
                  DonO
                  • Domenic T.
                    • January 29, 2010
                    • 2452
                    Re: Rustoleum paint
                    Larry,
                    I found Rustolium satin black at the hardware store here in CA. I was told that the larger cans (not rattle) have changed their formula but the rattle cans are the old formula. That does not make production sence unless it is a state restriction on quantity being used.
                    We are not allowed to paint inside at the airport, has to be outside and has a limit of 1 gallon per day. My shop is on the airport.
                    DOM
                    • Bill L.
                      • February 1, 2004
                      • 1403
                      Re: Rustoleum paint
                      One other positive with the paint is the ease with which it touches up and blends.
                      Really helpful when doing a body on type restoration piece meal.
                      Bill
                      • Michael J.
                        • January 27, 2009
                        • 7170
                        Re: Rustoleum paint
                        I wish they made this in hi-temp Chevy Orange.
                        • Ian G.
                          • September 3, 2007
                          • 1138
                          Re: Rustoleum paint
                          is the "satin black" a semi-gloss or semi-flat?
                          • Terry D.
                            • May 31, 1987
                            • 2697
                            Re: Rustoleum paint
                            Frederick You might want to check with them about shelf life. When I had a problem with their paint doing some wheels the first thing they asked for was the date code. Then told me old paint will sometimes crinkle up.Terrt
                            • Bill L.
                              • February 1, 2004
                              • 1403
                              Re: Rustoleum paint
                              Neither -I found the satin to be right in between semi gloss and semi flat.
                              Bill
