1963 p/b booster to pedal adjustment - NCRS Discussion Boards
  • Bob W.
    • December 1, 1977
    • 803
    can anyone tell me what is the right adjustment from the rod at the back of the booster to the brake pedal
  • Timothy B.
    • April 30, 1983
    • 5202
    Re: 1963 p/b booster to pedal adjustment
    Bob,
    I think it's adjusted so the brake pedal stands 5" from the floor and when compressed 2 1/4" the pedal should be hard.
    • Harry S.
      • July 31, 2002
      • 5344
      Also remember the 63 booster is unique. The section that inserts into the back of the master cylinder is also adjustable. Each 1/4 turn of the adjuster is about 1 inch of pedal movement. Don't have it adjusted too far into the MC as it will already start to apply the brakes.
      I think this is why this adjustment screw was removed, if you didn't get it right just touching the pedal would lock the wheels.
