70 Gas cap - NCRS Discussion Boards
70 Gas cap
  • Mike F.
    • April 25, 2011
    • 668
    70 Gas cap
    Is there a simple way to restore/replate/clean-up this cap at home or do I need to send it to Joe Perri?
    On second thought should I leave the patina?
    TIA,
    Mike
  • Edward J.
    • September 15, 2008
    • 6950
    Re: 70 Gas cap
    Mike, I would restore, unless your going for bowtie award. the gas cap has 18 pts. between originality and condition. you will get all the originality pts. but loose a few on condition. You want the dull Zinc finish.
    • Kurt G.
      • April 30, 2005
      • 343
      Re: 70 Gas cap
      Before you send it off, let it soak in Evaporust for a few hours. Yea, I know it's not rusty, but Evaporust will help clean it up and get some of the corrosion off.
      Kurt Geis
      Chairman, Midway USA Chapter
      Targa Blue 1972, Top Flight and Duntov Award, 2014
      Arctic White 1994, Top Flight, Hrt. of Amer. Reg. 2011
      Arctic White 2013 60th Anniv Special Edition Conv.
        • 43247
        Re: 70 Gas cap
        TIA,
        Mike
        Mike-----
        You could try to clean it up. However, I wouldn't use any solution which was acidic in nature (i.e. pH <7.0). That will remove the zinc plating.
        Also, I'd keep this cap just for judging. For other times, just obtain and use a GM #3994339. Original gas caps have a way "disappearing".
