It doesnt look like the connectors to the licience lights will pass thru the holes in the lid. I dont see how the wires and connectors will pass. Do the connectors need to come off? Thanks as always!!
					54 rear trunk lid harness Question
 Re: 54 rear trunk lid harness Question
 I did not have a problem
 Fish some metal wire from hole to hole with the grommets removed.
 tape the wiring harness to the wire tightly and the connector offset from one another - and pull thru.....1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
 Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
 1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
 1957 Corvette - FI 3 sp - Black and Silver- Top
 Thanks again Chris!...........a different question..........the brown wire for the horn button that needs to get soldered to the steerung column bearing, that new bearing needs to come out yes?- Top
 No the brown wire is already attached to the bearing
 fish a wire up for the horn and turn signal wiring
 Pull thru
 Install the bearing flush
 make sure to remove the paint from the end of the column1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
