kelsey repo tires fitment in spare tire tub - NCRS Discussion Boards
  • Mike M.
    • May 31, 1974
    • 8400
    anybody have trouble getting the kelsey repo(goodyear custom super cushion 6.70 x 15) mounted on an original K/O installed in an original unmolested tire tub? mike
  • Michael H.
    • December 1, 1987
    • 730
    Re: kelsey repo tires fitment in spare tire tub
    Mike,
    Are the bolts that hold the lid the correct length for KO wheels ? I believe they make a couple different lengths depends if steel wheels vs KO's.
    Mike
      Mike -
      The DOT requirement for inflation when the tire is still hot out of the mold makes the reproduction tire slightly larger in both cross-section and diameter than an original tire of the same size; that may be contributing to the problem.
      • Michael J.
        • January 27, 2009
        • 7145
        That explains why I had to get the longer bolts made for the redlines to make my new Kelsey GY PC's whitewalls (775X15s) in my '67's spare tire tub.
        • Mike M.
          • May 31, 1974
          • 8400
          i've got the correct front bolts designed for K/O's. the problem is the diameter of the kelseys is excessive, even when i deflate the tire. mike
          • Michael H.
            • December 1, 1987
            • 730
            I kinda figured you did. Years ago they had machines that would shave tires down for racing or if a tire was out of round it would true it up, maybe there's one close to you somewhere.
            Mike
            • Mike M.
              • May 31, 1974
              • 8400
              no tire shops around here that'll grind down the OD. i'll just mount it on my daily driver, a chevy pickup with a LS3 525 HP crate engine. few burnouts ought to do it. thanks for good suggestion. mike
