Do I need to be using a fuel additive with 5-10% ethanol gas? - NCRS Discussion Boards
  • Stephen W.
    • June 30, 2013
    • 50
    '66 327-350 'Vert #1241-- I can get non-ethanol 93 RON gas, but it's a hassle (quite a drive to the station).
    I drive my car regularly, or at least, start it up if not driving it. Should I be using a fuel additive (e.g., "carb defender" or similar) with each tank of ethanol gas?
    thanks
  • Larry M.
    • January 1, 1992
    • 2701
    Re: Do I need to be using a fuel additive with 5-10% ethanol gas?
    The short answer is NO........no additional additive is needed for ethanol-containing fuel.
    Larry
    • Michael W.
      • April 1, 1997
      • 4290
      No. Many of us have knowingly or unknowingly been driving 20-30+ years or more on E10. The sky is not falling except in Florida.
      • Michael H.
        • December 1, 1987
        • 730
        I use Lucas which is very simular to Defend and it was recommended by my carb rebuilder. I remember looking inside my carb before is was rebuilt and it had a lot corrosion in it from water. All the brass items had turned black. I'm not an expert in this field but I know my rebuilder is.
        Mike
        • Larry M.
          • January 1, 1992
          • 2701
          Mike
          Water/condensation may cause some corrosion, but it should not turn brass components black. Sulfur (high sulfur) in gasoline will however do this.
          Larry
          • Bruce B.
            • May 31, 1996
            • 2930
            Additives for fuel are a waste of money.
