67 clock loose minute hand - NCRS Discussion Boards
  • John G.
    • April 1, 1999
    • 50
    I had the clock on my '67 rebuilt last winter by clockworks. Installed it in the spring. After a 50+ miles on smooth Michigan roads the minute hand came loose. The minute hand was loose when I sent it to clockworks. They installed a NOS clock mechanism. I have the clock out. Is there a trick to getting those hands on tightly and keeping them on? Thanks for any suggestions.
  • Joe R.
    • July 31, 1976
    • 4552
    Re: 67 clock loose minute hand
    John,
    First I should tell you to send the clock back and have them fix it since that's what you paid for in the first place. But the added expense of shipping won't be worth it!
    OK, anyway here is how to fix the minute hand. You must be careful with this method and only use a very small amount of "Super Glue". Open the clock up and take off the second hand. Just pull it off. Take a toothpick and blunt one end. Dip it in a drop Super Glue that you have put on a smooth surface such as glass. Make sure the hour hand and minute hand are in proper position and touch the toothpick where the minute hand touches the shaft. Replace the second hand by pushing down on the center. Don't get a lot on toothpick and you'll be fine!
    JR
    • Michael J.
      • January 27, 2009
      • 7176
      Wow! Thanks for this, the same thing has happened to my '64's clock and I was wondering what I could do.
      • John G.
        • April 1, 1999
        • 50
        Originally posted by Joe Ray (1011)
        John,
        JR
        Thanks JR, I thought about doing something like that. I didn't know if there was a smart mechanical fix (ie squeezing the hand base...). I like the super glue idea. And you're right I should send it back to clockworks but it would be $26 to ship both ways.
        • John G.
          • April 1, 1999
          • 50
          Joe, The super glue fix worked very well thanks.
