54 wire harness ground question - NCRS Discussion Boards
  • Guy M.
    • November 1, 1993
    • 500
    There is a heavy gage ground wire that the schematic says it connects to the "shipping bolt" on the block. What is it saying, the mount? Its about an 8 gage wire with about a 1/2 inch or 5/8 connector. I havent seen any pictures showing this connection. Thanks again!
  • Chris S.
    • January 1, 2000
    • 1068
    Re: 54 wire harness ground question
    Yep !
    On the drivers side - on the trans/engine/adapter plate ( the middle one - one the engine bolts to and trans bolts to.- there is a hole towards the driver - I think it is a 7/16 bolt should be a TR or WB1C etc.....
    Shoot me an email and I can email you a photo
    The wire snakes over from the harness - two clips on the firewall.....one on the firewall ....one on the left side
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • Guy M.
      • November 1, 1993
      • 500
      Thanks Chris, a photo would be great. I really appreciate!!. gmcmann@jeffco.us I havent even seen this being mentioned anywhere.
      • Dan D.
        • November 5, 2008
        • 1323
        Ya wanta make sure that ground is on there good, as I believe that is the only ground means for all the equipment in the car, other than starter and gen.
        -Dan-
        • Chris S.
          • January 1, 2000
          • 1068
          Photo sent
          • Rob M.
            NCRS IT Developer
            • January 1, 2004
            • 12794
            Originally posted by Chris Sherman (33359)
            Photo sent
            why not post it on the forum so we can all see and learn (now and in the future)?
            Rob.
            NCRS Software Developer
            • Jerry P.
              • September 30, 1989
              • 85
              can you pls post a photo of the ground, thanks jer
              • Guy M.
                • November 1, 1993
                • 500
                • Troy P.
                  • February 1, 1989
                  • 1284
                  This shows the bolt the black ground wire with the white stripe it attaches to on the engine.Hall 54 029.jpg
                  • Rob M.
                    NCRS IT Developer
                    • January 1, 2004
                    • 12794
                    Originally posted by Troy Pyles (14528)
                    This shows the bolt the black ground wire with the white stripe it attaches to on the engine.[ATTACH=CONFIG]49240[/ATTACH]
                    thanks for taking the time to post!
                    Rob.
                    • Guy M.
                      • November 1, 1993
                      • 500
                      PERFECT Troy!! All these little hidden details is what makes this year model. Who needs a schtinken manual! Thanks fot your time, this will help everyone wiring this thing,
                      • Troy P.
                        • February 1, 1989
                        • 1284
                        Mystery - I can see why there is a bolt in the one hole as it secures the ground wire. But it makes no sense for GM to install a bolt in the other hole as it serves no purpose I can detect. Both holes were apparently used to attach the engine to the shipping cradle and for nothing else.
