Best paint for my 68 427 Smog Pulley? - NCRS Discussion Boards
  • Steve W.
    • March 1, 2002
    • 78
    I am refinishing my 68 smog pulley, any suggestions on the correct color and best paint to use? I've seen used ones in Black, and Grey. thanks for any suggestions. Steve
    • 15602
    Re: Best paint for my 68 427 Smog Pulley?
    The original finish, I believe (it is those pesky 1968s that give me pause), dark phosphate. this color can range from gray to black, but it has the sparkles in it. Paint will fool some of the people some of the time, but not the NCRS judges.
    • Steve W.
      • March 1, 2002
      • 78
      any suggestions for company that still applies phosphate? thanks!
      • Terry B.
        • August 31, 1999
        • 607
        Steve,
        Contact Bill Hodell at billhodel@sbcglobal.net That email may be dated but he advertises in the Driveline. He is the smog pump supplier to a large number of NCRS cars. Highly recommended.
        Terry Buchanan
        Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
        Corvettes Owned:
        1977 Coupe
        1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
        2003 Electron Blue Coupe
        2019 Torch Red Grand Sport Coupe
        • Bill C.
          • July 15, 2007
          • 904
          Give an IM to member Grant Wong.
          He sells parkerizing solution - I use it on all of the hood latch mechanism and the metal toe board heat shields.
          it is fairly dark in color (manganese) - you can also darken by using a cold dip blackening solution (black oxide) prior to the hot dip in the parkerizing stuff.
          Bill
          • Steve W.
            • March 1, 2002
            • 78
            thanks for the replies guys, steve
            • Robert M.
              • January 1, 1992
              • 78
              Hi Steve;
              I purchased a parkerizing concentrate from a local gun shop, as per the instructions mixed with distilled water and heated the solution with a hot plate, worked great on the smog pulley and hood catches.
              Bob
