C1 Brain Twister..can you answer this question?? Brake Drums - NCRS Discussion Boards
  • Joseph T.
    • April 30, 1976
    • 2074
    Here are two pictures of a 1st design big brake finned drum. Notice how the semi eliptical finger is pressed in on the face plate located in one of the hole cut outs.
    What was the purpose and was this done on all drums? Front and rear, big brake and standard drums?
    Joe
  • Chris S.
    • January 1, 2000
    • 1068
    Re: C1 Brain Twister..can you answer this question?? Brake Drums
    Joe
    On 1954 3803 - I have the same thing - I call it a locating hole or tang - since the drum will only go on one way....
    Mine has the standard drums with the anti chatter spring groove.
    I can get you photos if needed
    Done one purpose ?? I would assume so.....
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • Bob J.
      • December 1, 1977
      • 718
      Drums and hubs were balanced as an assembly........the tang locates the drum in the proper position.
      I'm told that is why early HD front brake fans had 6 holes.
      A mystery would be why Z06 had 5 hole fans.
      Bob
      • Justin B.
        • March 1, 1996
        • 478
        Hey Joe, My early 58' RPO684 has its original front and rear drums. The tang on the front drums are turned in like the one in your photo but the rears were not. Hope this helps!
        • Joseph T.
          • April 30, 1976
          • 2074
          Yes..same here.
          Plus my fronts are riveted to the hubs.
          • Chris S.
            • January 1, 2000
            • 1068
            mine too !!! - I left it that way - and I learned something with your question
            • Justin B.
              • March 1, 1996
              • 478
              Yes..same here.
              Mine are also riveted
