1954 Tunnel Repair for Floor Shifter - NCRS Discussion Boards
  • Chris S.
    • January 1, 2000
    • 1068
    Re: 1954 Tunnel Repair for Floor Shifter
    There repair is strong but it is just a seam - reason I V groove it - so you have a wide (wider) base of material on both sides....
    The mat or cloth over the top is extra insurance - who knows maybe gets in and stands on it ?????
    On this car - it is a cloth car (1953) - so I will go over the top of the seams with cloth - so it looks a little better.....
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • Chris S.
      • January 1, 2000
      • 1068
      Here is the trans tunnel -Done
      Top side is done
      I V grooved the seams - filled with Glasin - Sanded that seam down
      Cut strips of cloth to cover the seams and give it some strength
      Then resin over that
      You can also see a huge hole in the floor that I just finished
      6 inches wide by 31 inches long (some one cut the floor - looking for a VIN number)
      I sectioned it under the seat floor re-enforcement - no one will ever see it - plus the re-enforcement will add strength
      Same process - but after the strips - I covered the entire floor with a piece of Cloth for strength
      Done
