How is the drivability compare between small block and big block - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2580
    I have a 66 small block (L79) coupe and really enjoy driving it. The only option is power brakes that work great, but I could even live without them. I've been looking for a convertible, 66 or 67. I want another 350HP car and don't really car about options. I have looked at a number of cars from Mecum auction, dealers, and individuals. I haven't found the car that I want to spend money on yet.
    I found a guy through the Driveline that has what sound like a nice 66 at a decent price. The problem, if there is a problem, is that it is a big block car. It's a the milder 390HP car. I have not seen the car yet or obviously driven it.
    I want to drive and enjoy my cars. How does the drive compare between a SB and BB?
    Don
    Don Harris
  • Michael J.
    • January 27, 2009
    • 7119
    • Jim R.
      • June 30, 2001
      • 643
      Re: How is the drivability compare between small block and big block
      I think you would be happy with the 390hp I liked mine in a 1970, and also feel that the L79 is about as good as you can get for a all around driver great power and driveability IMO
      JR
        • 15667
        The 427/390 is less high strung than the L-79, which has good driveability. The reduced valve overlap certainly makes L-79 easier to deal with around town than any mechanical lifter small block, and L-36 has less overlap than L-79
        The downside to any big block is higher fuel consumption, not quite as nimble handling, and probably a much higher price than the same year with a L-79. Also, internal engine parts are much more expensive.
        One the upside the 390 HP offers massive low end torque that will provide spirited acceleration even with a 3.08 axle, which yields more relaxed highway cruising.
        • James N.
          • November 1, 1991
          • 98
          If you go with the BB, get power steering. There is a noticeable increase in weight over the front end with a BB. My $0.02
          • Joe R.
            • May 31, 2006
            • 1822
            Jim,
            I will admit that I have not driven a BB with power steering. But my BB with manual steering is fine for me. It is a bit of work at parking lot speeds, for sure. Other than that, it's great, good feel, no complaints.
            Joe
            • Richard M.
              • April 1, 1993
              • 198
              Don't be afraid of going BB I have a 66 L36 Coupe myself with no P/S or P/B, good exercise for the arms in the parking lot but not bad on the road, you can always add P/S. You will love the bottom end torque, gas mileage is not that bad on the highway. Run AC R-45 heat range spark plugs to reduce plug fouling.
              • Donald H.
                • November 2, 2009
                • 2580
                Thanks all. The heavier front end was what I was most concerned about. E.g. steering and handling.
                Thanks again,
                Don
                Don Harris
