Rear storage compartment frame repair - NCRS Discussion Boards
  • Kurt G.
    • April 30, 2005
    • 343
    My original rear storage compartment frame has a crack in one corner. Fortunately it is between two of the screws so it doesn't shift around. Does anyone know what kind of "glue" I can use to repair the crack and make it one piece again? Thanks in advance.
    Kurt Geis
    Chairman, Midway USA Chapter
    Targa Blue 1972, Top Flight and Duntov Award, 2014
    Arctic White 1994, Top Flight, Hrt. of Amer. Reg. 2011
    Arctic White 2013 60th Anniv Special Edition Conv.
  • Dale C.
    • November 1, 1999
    • 844
    Re: Rear storage compartment frame repair
    Kurt, I use two types, for the small crack type break I use Weld-On 2354, it's for the ABS and Styrene plastics. Real fluid and a small amount on each side or just let penetrate the crack and clamp. It dries fast and sets in a day or so. For the larger breaks, that require filling or build up, I use the Devon 22045 Plastic Welder. Did you see my thread on hinge color about using the aluminum strips ? Dale
    • Kurt G.
      • April 30, 2005
      • 343
      Dale. I didn't see that post. I checked the archive and must have missed it. The crack I have is a clean break, so I guess the Weld-on should work. Can you make a suggestion where I might find the two adhesives you mention. Thanks.
      Kurt Geis
      • Dale C.
        • November 1, 1999
        • 844
        I think both are on Amazon. The thread is close to this one right now. Dale
        • David H.
          • June 30, 2001
          • 1526
          Kurt, I have some industrial adhesives that work pretty well on plastics. I picked them up at Carlisle. I'll bring them by so you can see if they work for you.
          • Bill L.
            • February 1, 2004
            • 1403
            I have used Dyna-Weld for similar repairs. May I add that you may want to make a thin flat plastic piece from similar material to place on the underside. Use the Dyna-Weld between the frame and small piece then clamp together overnight. rough up both parts where needed and make sure they are squeaky clean.
            I repaired my original cracked interior quarter covers using this method.
            Bill
