396 fly wheel - NCRS Discussion Boards
396 fly wheel
  • Bill W.
    • March 1, 1980
    • 2000
    396 fly wheel
    I just removed the flywheel from my 65 bb chassis it has 3791021 cast in the back with a date of D55 . my car is #17346 and was built in May 65 . Is this the original ? I have seen photos of "lightweights" and I dont remember them looking like mine . If its not what is the correct casting / part number for a new one . Thanks Bill .
  • Carl N.
    • April 30, 1984
    • 592
    Re: 396 fly wheel
    Bill, I believe the 3791021 is p/n 3973452 which was for most 63-68 except powerglides and heavy duty clutch applications. The L78 used p/n 3868806 - I'll have to find the casing number - search old threads from this summer - there was a thread with lot of info / discussion on large vs small diameter flywheels
    • Carl N.
      • April 30, 1984
      • 592
      Re: 396 fly wheel
      Bill, this place had a couple of 3868806 in stock several years ago - KMB Warehouse - the phone number is (718)931-2026 - casting dates will be 1966 but I don't think flywheels are being judged (but I could be WRONG)
      • Tom P.
        • April 1, 1980
        • 1814
        Re: 396 fly wheel
        I can't swear to the casting number, but in 1965, ALL Corvettes with a manual tranny (including the 396) had the smaller, 12 3/4in diameter flywheel with 153 teeth. They WERE NOT the light weight version. The ones I've seen (which is VERY few from a Vette) appear to be the standard type 63-later 153 teeth (heavy) flywheels.
        ON A CORVETTE--------the larger, 14in diameter, 168 teeth flywheels were introduced in 66.
        Beginning in 1955, ALLLLLLLLLLLL Chevy V8 engines had the larger, 168 teeth flywheel up through 62 (that's all there was on ANY Chevy V8). When the smaller, 153 teeth flywheel was first used in 63--------------DEPENDING ON ENGINE--------full size Chevys came with both 153 and 168 teeth flywheels. Thus, TWO different size bell housings and two different mounting configurations for starters were used.
        • Michael H.
          • January 29, 2008
          • 7477
          Re: 396 fly wheel
          Bill,
          I haven't looked up your 3791021 number but that sounds like a standard 153 tooth flywheel for 10.5" clutches for about 1961 and later.
          The 65 Corvette with 396 engine used a 153 tooth wheel too but it was a "light weight" design. (listed as 15 lb) The same wheel was also used for 67-69 L88 Corvette.
          • Wayne M.
            • March 1, 1980
            • 6414
            Re: 396 fly wheel
            Well that makes two of us, Bill. My L78 #23564 (last out the door in August, per GM [or Friday 30 July, per NCRS dealer delivery data service ; take your pick ]) also has the ...021 flywheel, cast date G_2_5 (July 2nd). Unfortunately the original 396 block was sold to a scrap metal dealer about 1980. I've had the car since 1988, and prior to that it has never been owned by an NCRS-type numbers enthusiast.
            • Joe R.
              • May 31, 2006
              • 1822
              Re: 396 fly wheel
              Carl,
              Is this the thread you were thinking of?
              https://www.forums.ncrs.org/showthre...083#post677083
              Joe
                • 43202
                Re: 396 fly wheel
                All------
                1965 L-78's were supposed to have been equipped with a 12-3/4" light weight flywheel. Originally, it was GM PART #3866735. Were all original L-78's equipped with this flywheel? I don't know. In any event, you can still obtain a flywheel from GM which is virtually identical to the original under GM #14085720.
                  • 43202
                  Re: 396 fly wheel
                  Carl-----
                  If you call KMB, have fun dealing with those guys!
                  • Carl N.
                    • April 30, 1984
                    • 592
                    Re: 396 fly wheel
                    Joe, yes thanks for looking it up
                    • Bill W.
                      • March 1, 1980
                      • 2000
                      Re: 396 fly wheel
                      Thanks everybody . My car went through a couple engine changes but most of the bolt on were still correct . The cast date on my 021 flywheel is about 5 weeks before my car was built so I guess it could be original ? I ordered a new light weight today & will pick it up tomorrow .
                      • Michael H.
                        • January 29, 2008
                        • 7477
                        Re: 396 fly wheel
                        I installed the 15# flywheel (and clutch, clutch housing etc) in my 425 HP 66 car about 30 years ago. Did the same for one of my 63 FI cars too.
                        • David L.
                          • July 31, 1980
                          • 3310
                          Re: 396 fly wheel
                          My 1965 Chevrolet Parts Catalog (May 1965) lists GM # 3866735 as the part number for the 65 Corvette (396) flywheel in Gr. 0.666. The description is as follows: "solid type (six 15/32 holes marked "V" and 1 marked "W")". My 1965 Chevrolet Parts Catalog (Jan. 1965) does not list a flywheel for the 65 Corvette (396) since the 396 option was not added until mid production.
                          GM # 3866735 is a service part (Casting # 3856579, I believe) and who knows when it was first used on the assembly line. Does anyone have a 3856579 flywheel with a 1965 casting date before July 1965?
                          GM # 3866735 was replaced with GM # 3991406 in Oct. 1971 as per Chevrolet Parts History.
                          • David L.
                            • July 31, 1980
                            • 3310
                            Re: 396 fly wheel
                            I have a book entitled "Corvette Restoration State of the Art" (1981) that is about the ground up restoration of a very original 1965 Corvette (396) w/M.T. The engine is stamped "T0329IF" (March 29, 1965). On page 74 there is a photo of the backside of the engine. The flywheel appears to be a 3856579 (cast. #) flywheel as you can clearly see the pairs of "bosses" (each with a small hole) between the pressure plate bolts. There are a total of 6 pair of these "bosses" on the face of the 3856579 flywheel. The 3791031 flywheel does not have these "bosses".
                            The flywheel currently on Ebay in the link below shows the 12 "bosses" on the face side of the flywheel.
                            Dave
                            • Michael H.
                              • January 29, 2008
                              • 7477
                              Re: 396 fly wheel
                              The flywheel currently on Ebay in the link below shows the 12 "bosses" on the face of the flywheel.
                              Dave
                              http://www.ebay.com/itm/Chevrolet-42...d46d48&vxp=mtr
                              David,
                              I'm not sure if that's the original flywheel in that car.
