Correct '64 327/300 Valve Cover "Metal" Embossed Label - NCRS Discussion Boards
  • James W.
    • December 1, 1990
    • 2658
    Does anyone know if any of the Corvette parts venders sells the correct metal embossed valve cover label for a '64 327/300 engine? I received a points deduct for these being NTFP at the last regional meet and would like to get this corrected if they are available.
    Also I need the correct "water-soluble" 300 horsepower decals if they are available as opposed to the NTFP adhesive stickers.
    James West
  • Michael J.
    • January 27, 2009
    • 7122
    Re: Correct '64 327/300 Valve Cover "Metal" Embossed Label
    You mean like this?
    • James W.
      • December 1, 1990
      • 2658
      Michael,
      Yes those are the one, I also found them on the Paragon catalog too. Now if I could find those embossed metal valve cover labels.
      Thanks for the reply.
      James
      • Michael J.
        • January 27, 2009
        • 7122
        Right, you need the metal embossed ones like this, except not paper like these:
        As most I have seen are paper like that. I have not seen metal ones, maybe someone else has?
        • Harry S.
          • July 31, 2002
          • 5310
          LIC, items 02-11H and 02-11J
          • Michael H.
            • January 29, 2008
            • 7477
            Didn't the 327 valve cover plate change at some point during the 63 model year?
            • Michael J.
              • January 27, 2009
              • 7122
              LIC has them listed this way: 11H is the metal one for '63, 11J is mylar, for the late'63-'65. Sure you are supposed to have the metal one for a '64? I know the TIM&JG says that, LIC must not know that?
              • James W.
                • December 1, 1990
                • 2658
                On on my judging sheets from the 2012 regional meet in Rochester MN., the judge noted that the valve cover emblem should be metal and the horsepower decals should be water soluble just like the current 63/64 TGJM describes for a 1964 Corvette equipped with a 327/300. These were only small point deducts and are easy to fix. I'm just trying to make it correct for the national convention.
                James West
                • James W.
                  • December 1, 1990
                  • 2658
                  My point exactly. The 1964 A.I.M. shows part number 3832180. I would assume that this is the mylar sticker type label which should be correct for a mid-production 1964 Corvette. I really don't want to change whet I believe to be correct even though the TGJM says that all 63-64 250-300 hp equipped cars are to have the metal de-bossed label.
                  Any further comments from anyone?
                  Thanks again for all the responses.
                  James West
                  • Gene M.
                    • April 1, 1985
                    • 4232
                    Mike,
                    Correct me if I'm wrong. Was not '63-'64 the metal plate with raised numbers and '65 the start of the flat label?
