rubbing compound - NCRS Discussion Boards
rubbing compound
  • Lyndon S.
    • April 30, 1988
    • 1027
    rubbing compound
    Rubbing compound that has dried, anyone know of something that will remove this? Some one before me let some dry bewteen the lower edge of the hood an bumper.
  • Matt L.
    • February 23, 2010
    • 337
    Re: rubbing compound
    hi Lyndon,
    try some hot soapy water and a towel. if towel is not aggressive enough try a soft brush like a paint brush. that should do it. i have also hot pressurewashed it away but you risk blowing the clear off. i hope this helps.
    take care,
    Matt
    • Paul H.
      • September 30, 2000
      • 688
      I have also had good luck with a little Isopropyl alcohol or Goo Be Gone.
      • Paul S.
        • June 30, 1982
        • 359
        Wd40, let it soak then wipe it out . Won't hurt the paint
        • Michael J.
          • January 27, 2009
          • 7175
          A toothbrush is also very handy to use in tight places, use a soft one.
          • Dick W.
            • 10483
            Baby oil works
            Dick Whittington
            • Jeff P.
              • July 23, 2010
              • 29
              I might try to clay - bar the car... the detail spray would lubricate it enough for the clabar to "grab" the impurities.....if it works I would do the entire car so that the surface would then be uniform.
