'92 Factory Security System - NCRS Discussion Boards
  • Terry B.
    • August 31, 1999
    • 607
    I looked at a '92 Coupe a few days back. It is a low mileage car and it looks very well cared for. Very nice and clean with original equipment except it has what looks to be a well installed aftermarket security system. It has a key fob that will lock and unlock the doors and chirps when activated and deactivated. The problem I'm having is I do not know what the original '92 cars had as a security system and how it worked. Through a search on the internet, I have found that there is some type of sensor on the key that is used but that is about all I know. Could a '92 owner or someone very familiar with '92's answer my questions:
    1. What is controlled in the '92 security system? Doors, hatch, other?
    2. How do you engage the security system?
    3. How do you turn the security system off?
    4. Does the horn sound when you set the security system or do the lights flash?
    5. What happens if the system is set off?
    6. Any problems with the security system?
    Any other insight or info on the security system is appreciated.
    Terry Buchanan
    Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
    Corvettes Owned:
    1977 Coupe
    1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
    2003 Electron Blue Coupe
    2019 Torch Red Grand Sport Coupe
    • 6955
    Re: '92 Factoryl Security System
    Terry, I answered your post above.
    • Tom H.
      • December 1, 1993
      • 3440
      I emailed you the functions and operation of the 92 system !
      Tom Hendricks
      Proud Member NCRS #23758
      NCM Founding Member # 1143
      • Tom H.
        • December 1, 1993
        • 3440
        Audible warning is sounded using the horns if the doors or hatch has an unauthorized entry. System is engaged when the power lock is moved to the lock position. The system is disarmed by using the oval head key in the door lock cylinder. Horn will sound when the alarm is activated. ( That is the short version of what I emailed you.
        Tom Hendricks
        • Terry B.
          • August 31, 1999
          • 607
          Thanks Tom and Ed. All my questions have been answered.
          Terry Buchanan
          Corvettes Owned:
          1977 Coupe
          • Bill H.
            • August 8, 2011
            • 439
            Terry, yep, the fob is aftermarket and the siren that chirps is too. I installed this type of system in my 92. You have an alarm, siren and somewhere there's a circuit board with 2 relays on it to operate the door solenoids. The Security light is part of the 92's Theft Deterrent System. The flashing security light on the dash is a reminder to arm the system (by using the power lock button on the door panel). The system will then activate if the door or hatch is opened. The horn will sound for 3 minutes and the starter will not work until the proper key is put in the ignition (part of the VATS system with the resistor in the key). If you use the key to lock the door from the outside, the system will not arm. I've had zero problems with the system. However, the aftermarket alarm has a quirk in that if I lock the door from the inside and then hit "lock" on the fob, the GM alarm (horn) will go off. No problems if I just use the Fob. And I'm too lazy to mess with it to see if it can be fixed.
            • Jim T.
              • March 1, 1993
              • 5351
              If you buy this car, hope it comes with an owners manual, it will cover the 92's security system.
