68 L 89 Crank anyone know the correct crank part number? - NCRS Discussion Boards
  • Steve W.
    • March 1, 2002
    • 78
    I've red 6223 but I've also seen 7115 cranks as being listed as the correct crank. Anyone know for sure? thanks, Steve
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: 68 L 89 Crank anyone know the correct crank part number?
    Per Colvin's book, the L89 should take the 7115 cast crank [with the (wider) heavier counterweights, because of the heavier pistons]. This would apply to all 427 c.i. engines.
      • 43285
      Wayne-----
      L-89 used the exact same pistons as L-71. L-89 is simply an L-71 with aluminum heads.
      L-89 used crank GM #3882842. This crank could have had forging number 6223 or 3856223.
      The '7115' crankshaft was GM #3967811. It was used for later 1969 L-88 and ZL-1. However, it can be used for L-89, L-71, or, for that matter, any 427.
      • Steve W.
        • March 1, 2002
        • 78
        thanks for the replies guys, Steve
