1966 Inner Door Panel Black Out - NCRS Discussion Boards
  • Bob P.
    • June 30, 1998
    • 143
    I need some help determining how, if at all, was the inner fiberglass door panel blacked out. I have been told that original interior door panels had black tape or black paper attached to the top of them that covered the top couple of inched of the inner fiberglass door panel, but I can't seem to find any information about this. Your help with determining if this is correct and then what material the black out piece was made of and what was it's length and width. Thanks
    Bob Puls, 30633
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: 1966 Inner Door Panel Black Out
    There was a black crepe paper attached under the trim.
    • Bob P.
      • June 30, 1998
      • 143
      Thanks for your help. When you say black crepe paper do you mean like you use to decorate with? Was it attached to the top of the inside of the interior door liner and then draped over the inner fiberglass portion of the door or was it just attached to the inner fiberglass portion of the door at the top and then the interior door liner was assembled on top of it? How was it attached? Again thanks for you help!
      Bob Puls, 30633
      • Gary B.
        • February 1, 1997
        • 7053
        Bob,
        No, it's not like the crinkly decorative crepe paper. I might be able to take a photo tonight of the original material on the door of my '66, presuming I didn't remove it when I took off the door panel and removed the window and other parts. I do think the black material might have started out as something like black masking tape, which after 47 years becomes stiff and brittle and easily torn like paper.
        Do none of the Corvette catalog companies sell a replacement item? Have you tried asking Dr. Rebuild, Long Island Corvette or Paragon, for example?
        Gary
        • Bill W.
          • March 1, 1980
          • 2000
          It is a black water proof paper that covers the door . it is put on with strip calking . There is also black paint sprayed on at the handle areas . and the door trim panels should be blacked out below the fuzzy window wipes . I think long island sells the paper .
          • Gene M.
            • April 1, 1985
            • 4232
            I think you guys are talking about two different things. 1.- Is the vapor barrier that is black on the side towards the interior and brown on the side against the fiberglass door stuck on with string dumb dumb. 2.- Is the black tape (no mention in AIM) that runs along the top edge of the outboard side of the inner fiberglass door. Now sadly enough #2 is not on all cars. I don't know if it is an AO Smith thing or St Louis. I have not paid that much attention to it. Nor do I recall what years it is seen. I do recall the black paint thing too that was mentioned!
            • Bob P.
              • June 30, 1998
              • 143
              Thanks to All. What I'm talking about is #2 that Gene mentions and he is correct, it is not in the AIM or the Judging Manual for '66. So, there should be black paint below the fuzzy window wipes? Any idea how far down the paint goes? My guess is that the paint won't mask the inner fiberglass door panel when you look into the inside of the door though? I guess this is why the black tape was used?? I have never seen it, but makes sense to me as to why it would be there. Any idea of how wide the tape was and did it go all the way across the top of the inner fiberglass door panel?? Thanks
              Bob Puls, 30633
              • Bill W.
                • March 1, 1980
                • 2000
                The black under the fuzzies is on the vinyl door trim panel . It was on STL. cars . I'm not sure about AOS. The black spray was on at least 63 through 65 .
                • Bob P.
                  • June 30, 1998
                  • 143
                  Bill, I want to make sure I understand. Are you saying that the back side of the vinyl door panel below the fuzzies was painted black on 63 through 65 STL cars and your not sure about AOS?
                  Bob Puls, 30633
                  • Gary B.
                    • February 1, 1997
                    • 7053
                    Bob,
                    I'm not sure these photos will answer any of your questions, but this is what's under the door panel on my StL '66 with late July build date. The tan paper is black on the side that faces the fiberglass. Some of the black you see is the black, masking-like tape.
                    Gary
                    • Gary B.
                      • February 1, 1997
                      • 7053
                      Bob,
                      Here's a photo from Rich Mauser's '66 that he said I could post. I'm not 100% sure what I'm looking at in his photo, but Rich says it shows the masking tape. Rich says a mirror was used so you can see the front and back side of the same piece of tape.
                      Gary
                      • Bill W.
                        • March 1, 1980
                        • 2000
                        Robert check your e mail tonight .
                        • Bob P.
                          • June 30, 1998
                          • 143
                          Gary, Thanks it looks like your car is a coupe? Besides seeing the black tape, which looks like it would be covered by the door panel, I noticed that there are places where the top edge of the inner fiberglass door portion of the door is painted black. Is the inside of the inner fiberglass door panel painted black at the top as well?
                          Bob Puls, 30633
                          • Bob P.
                            • June 30, 1998
                            • 143
                            Gary, Looks like this is a picture taken into a mirror. Not sure where the mirror is placed though. Is it between the inner and outer fiberglass door panels where the window glass would be or is it just up against the inside of a vinyl door panel??
                            Bob Puls, 30633
                            • Gary B.
                              • February 1, 1997
                              • 7053
                              Originally posted by Robert Puls (30633)
                              ... Is the inside of the inner fiberglass door panel painted black at the top as well?
                              Not that I can see.
                              Gary
