stainless sleeving of master/wheel cylinders - NCRS Discussion Boards
    • May 31, 1974
    • 8391
    about 2 years ago, i had the master cyl in a 56 vet done by a shop whose address i've misplaced(i never misplace the beast). anyway, i need a 65 mc sleeved. anybody have a favorite shop . the shop i used 2 years ago was recommended by this tdb.. thanks,mike
  • Dick W.
    • 10483
    Re: stainless sleeving of master/wheel cylinders
    CSSB ( The bus boys John and Luke) have done several for me Doc
    Dick Whittington
    • Harry S.
      • July 31, 2002
      • 5310
      My 63 was done by Brake and Equipment Warehouse in Minneapolis (612) 378-3141 (800) 233-4053. Very quick turn around, looked like a new Master Cylinder. I had them do the cleaning and install the sleeve, and I rebuild with a new kit. They charged $95 and that includes the return postage.
      • Keith B.
        • March 7, 2008
        • 928
        Was it White Post Restoration in VA
          • May 31, 1974
          • 8391
          thanks all u guys. harry recommended the minneapolis shop couple years ago. they were the ones i was looking for. thanks again.mike
          • Dan B.
            • July 13, 2011
            • 545
            Another vote for Brake & Equipment Wharehouse. Done once and done right!
            • Chris S.
              • January 1, 2000
              • 1068
              White Post did mine....wheel cylinders and brake master
              • Harry S.
                • July 31, 2002
                • 5310
                Mike, did the shop in Minneapolis do your MC? If yes, are you OK with the work? I just sent them my spare 63 MC to insert a SS sleeve.
                  • May 31, 1974
                  • 8391
                  i had them do a 64,65 and 66 MCs. reasonable price, quick turn-around and no leaks. i'm well satisfied . mike
                  • Harry S.
                    • July 31, 2002
                    • 5310
                    Great, thanks....
                    • Richard M.
                      Super Moderator
                      • August 31, 1988
                      • 11324
                      For you guys that had sleeves installed.....
                      I had a '60 MC handed to me that was sleeved in brass. Used DOT 5 silicone fluid. BTW, last several C1/C2's I've done are DOT 5 and I'll NEVER go back to DOT 3.
                      When I bench bled it after a Corvette Central MC kit, it chugged(like a slightly jerky feeling) and squeaked like crazy. I thought it may have been due to using that older CC MC rebuild kit, so I took it apart again and installed a brandy new NAPA rebuild kit......Same squeaky, jerky, chugging, bench bleed. I installed on the car and bled the whole system. Brakes are fine, but I can feel & hear a slight squeakiness and jerkiness in the pedal. The more I use the brakes it appears to be getting less noticeable.
                      The other past DOT5 restorations didn't have this oddity, but they were brand new MC's, not sleeved.
                      Anybody ever notice this on their sleeved MC's?
                      • Bill M.
                        • April 1, 1977
                        • 1386
                        The C4 is designed to use DOT3 brake fluid in the hydraulic clutch. There used to be a special brake fluid available from GM for the clutch that eliminated squeaking as you actuated the clutch master cylinder. The squeaking as you cycle the cylinder must be a common issue....
