Blacken Stuff - NCRS Discussion Boards
Blacken Stuff
  • Rey S.
    • April 1, 1995
    • 277
    Blacken Stuff
    How do I blacken nuts and bolts here in my garage?
    Rey Stenhouse 26007
    1972 LS-502 Coupe
  • Dick W.
    • 10483
    Re: Blacken Stuff
    Eastwood, Caswell, etc sell kits. You just need a little heat, a container, and the chemicals. Not a big deal
    Dick Whittington
    • Rey S.
      • April 1, 1995
      • 277
      Re: Blacken Stuff
      Thank you Dick
      Rey Stenhouse 26007
      1972 LS-502 Coupe
      • Bill W.
        • March 1, 1980
        • 2000
        Re: Blacken Stuff
        I have had very good luck with gun blue . I glass bead then wire brush with a fine wheel ,put them in a jar with a few drops of gun blue a quick wipe down then a jar of oil . they look just like the ones from the vendors .
        • Chris S.
          • January 1, 2000
          • 1067
          Re: Blacken Stuff
          I tried Caswell - didnt like it
          Sent them out to be professionally done by Detail Plating.
          1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
          Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
          1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
          1957 Corvette - FI 3 sp - Black and Silver
          • Rey S.
            • April 1, 1995
            • 277
            Re: Blacken Stuff
            Sounds easy enough. Would you elaborate a little more on the procedure.
            Rey Stenhouse 26007
            1972 LS-502 Coupe
            • Dale O.
              • May 31, 1995
              • 52
              Re: Blacken Stuff
              Take a look at this web site. http://parkerizingkits.com/index.html I have been using this for black and works great.
              • Steven B.
                • June 30, 1982
                • 3990
                Re: Blacken Stuff
                Bill, have you or anyone tried sanding instead of glass beading? If so how did it work? It would seem that sanding would not get into all the areas beading/blasting/dipping does and not have a consistent look?? Thanks! Steve
                • Bill W.
                  • March 1, 1980
                  • 2000
                  Re: Blacken Stuff
                  Steve .I glass bead everything that gets all the rust and old plating off . The fine wire brush on a bench grinder gives the part a smooth shinny finish the I put a few bolts ,washers or nuts in a small jar and add a a few drops of gun blue swirl it around until all parts are black remove them with a magnet , quick wipe down the soak in oil for a few minutes remove place on paper towel and your ready to go .
                  You can only use the blacking liquid once . You will learn how much to use . Also you can use any kind of oil ,stp,rear end lube etc. I dont think sanding will work .
                  • Steven B.
                    • June 30, 1982
                    • 3990
                    Re: Blacken Stuff
                    Thanks Bill! Steve
                    • Dick W.
                      • 10483
                      Re: Blacken Stuff
                      I dip in a strong phosphoric acid solution before dipping in the blackening solution
                      Dick Whittington
                      • Steven B.
                        • June 30, 1982
                        • 3990
                        Re: Blacken Stuff
                        Dick, how long do you keep parts in the solution? (As long as it takes to eat a piece of chocolate cake?)
                        • Steve L.
                          • June 30, 2001
                          • 763
                          Re: Blacken Stuff
                          I clean the crud off with acetone if required, blast, then a quick dip in muriatic acid(about 10 seconds) followed by washing in distilled water. The Caswell blackening about 30 seconds. Wash in distilled, dry immediately or it will surface rust immediately. Then satin clear. Caswell has a sealer but I don't use it since it looks like an oil base.
                          Others will use Parkerizing which probably is better.
                          I don't wire brush since I have bolts launching and nuts are too hard to hang onto. A brass wire wheel would be better but it's near impossible to find a real brass wheel. Most are brass plated steel. A magnet will sort that out fast.
                          Still others will have a better opinion on to getting the plating to be exact to factory but it will be more hassle.
                          In any case, most blackened hardware from the factory should have been outlawed since long term corrosion protection is poor at best.
                          I haven't seen a workable solution to sending out a bucked full of parts to a platter. This would be the best solution but I haven't seen how to really keep track of it. The home restorer typically does sections of restoration at a time, meaning that the amount of hardware will be a small handful. Platters charge by the pound and will not bag and tag. I'm paranoid of losing track of nuts, washers and bolts at each location plus the direction and stack-up of assembly on some locations. All of this is written down on paper in each bag. Even with that, I sometimes lose track and have to ask for help or the AIM.
                          Do a search on this, This topic has been covered to death.
                          Steve L
                          73 coupe since new
                          Capital Corvette Club
                          Ottawa, Canada
                          • Donald H.
                            • November 2, 2009
                            • 2580
                            Re: Blacken Stuff
                            I purchased a Parkerizing kit from a firearms accessory company call Shooter Solutions. Do some Google searcher on the Parkerizing process which is Phosphating. There are two different solutions Zinc Phosphate, which produces a light gray to medium gray color, and Manganese Phosphate, which produces a dark gray to black. The picture below is of a typical zinc plated bolt that I put through the phosphating process.
                            The kits are very inexpensive and easy to use. Basically you remove any current zinc plating or other plating from the steel piece and clean it very good. The manganese or zinc phosphate solution is heated and maintained at just below boiling point and the part is dropped in. I used our kitchen cook top and a pyrex dish.
                            Don Harris
                            Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
                            • Dick W.
                              • 10483
                              Re: Blacken Stuff
                              Depends. I use the solution to clean the rust off. It is sort of trial and error, doing, pulling it up to inspect, dipping again until it is clean
                              Dick Whittington
