year of hardtop? - NCRS Discussion Boards
year of hardtop?
  • Steve Z.
    • July 30, 2008
    • 28
    year of hardtop?
    Any way to tell the year of a hardtop? Just wondering if there are any markings or stamps to designate year for a 68-75? Thanks for your input. Steve
    • 15606
    Re: year of hardtop?
    Date on the window, perhaps? 1968, at least early in production, did not have the bright rear tips, and the early front latches had a different configuration than later latches. Early 1968 roof latches used an acorn nut in contact with the body; later used a rubber pad. Check the TIM&JG for approximate change point.
    • Michael D.
      • June 30, 1996
      • 536
      You may find date stamps on the backsides of the upholstered pieces.
      • Jim T.
        • March 1, 1993
        • 5351
        Terry any information on when the 1968 model year stopped using the acorn nut and started using a rubber pad? Also the bright rear tips on the 68's hardtop, when did they begin?
          • 15606
          Jim,
          I would have to look in the new TIM&JG and I don't have a copy here at work.
          • Reba W.
            • 938
            Jim, the manual says rear tips were added sometime during July 1968. I didn't work on that section so I don't know if this is new info or if it was in the old JG. It also says that acorn nuts were used in 1968 and rubber pads in 1969. That probably is too vague, but no research was done for that.
            • Patrick N.
              • March 10, 2008
              • 954
              TIMJG has the bright protective trim tips occurring during July 68
              • Jeff P.
                • October 21, 2011
                • 287
                Letter codes on the glass in the lower left corner, also seen crayon writing on the inside of the top under the interior liner. 68 also has 1/4" rear bow pins.
                • Steve Z.
                  • July 30, 2008
                  • 28
                  Would the crayon writing be a vin or what? Just bought a hardtop last night and was wondering how to date it. No headliner in it, but I didn't see any obvious writing. Will check the glass for date. Thanks Steve
