Help fine cleaning frame - NCRS Discussion Boards
  • Steve L.
    • June 30, 2001
    • 763
    Re: Help fine cleaning frame
    Scott, I figured it was a 73 because you posted for 73-77 and one of pix shows the cutout for the exhaust which the later ones do not have, rear bond lines, extra nut on the rear x member, bumper struts bolt holes were used, rear fiberglass, rear vapor line.
    Steve L
    73 coupe since new
    Capital Corvette Club
    Ottawa, Canada
    • Michael L.
      • December 1, 1998
      • 97
      Hi All
      Were are sone of the shops that can dip and prime you frame. I am in the New Orleans area
      Michael
      Michael E Leeds
      Charter Member
      Past Chairman Louisiana Chapter
      Past Vice Chairman Louisiana Chapter
      Past Show Chairman
      31462-La-46
      River Ridge LA
      www.ncrs-louisiana.com
      • Michael L.
        • December 1, 1998
        • 97
        #18
        Hi All again
        What is the normal price to Dip a frame and parts and prine?
        Michael E Leeds
        Charter Member
        Past Show Chairman
        31462-La-46
        River Ridge LA
        • Scott F.
          • September 16, 2013
          • 50
          #19
          Hi Michael, I am sorry but I don't have a clue about that.
          Scott
          • Michael G.
            • March 2, 2008
            • 486
            #20
            The wire wheel process can be used to obtain a good result. These wheels are available in different aggressive configurations and should be used like you would use sandpaper. Course down to fine. Conical brushes for tight areas and such. No argument here as far as the greater results with body off and blasting or dipping but wire brush route can do a pretty good job if you do a pretty good job yourself.
