63 non stock wheels - NCRS Discussion Boards
63 non stock wheels
  • John M.
    Infrequent User
    • February 1, 1985
    • 26
    63 non stock wheels
    I recently bought a '63 coupe that has P235R60-15 tires on 7" wheels. Stance looks good, but I am concerned with the size of the tires. Has anyone used this compination of wheel and tires? What is the largest wheel and tire combination that I can feel comfortable with? Thanks for your help.
  • Timothy B.
    • April 30, 1983
    • 5196
    Re: 63 non stock wheels
    John,
    IMO, they are to wide and I would be very careful that they don't rub the frame or fender at full lock and be very careful going over bumps like a driveway that they don break the fender. I know the 60 series tire is shorter so check carefully.
    • John M.
      Infrequent User
      • February 1, 1985
      • 26
      Thanks, that was my concern also.
      • Steven B.
        • June 30, 1982
        • 4000
        John, I am sure you have but don't forget to check off set of wheels. Does the front rub lock to lock?
        • Gary C.
          Administrator
          • October 1, 1982
          • 17771
          John,
          Do a search, this has been discussed multiple times on the TDB.
          Gary
          NCRS Texas Chapter
          https://www.ncrstexas.org/
            235/60's on 7" rims is a recipe for broken fiberglass.
            • Rick A.
              • July 31, 2002
              • 2147
              John,
              FWIW, I run 215-65-15's on my 1963 Z06 and have no rub what-so-ever
              Rick Aleshire
              2016 Ebony C7R Z06 "ROSA"
                Originally posted by Rick Aleshire (38392)
                John,
                Rick -
                There's a HUGE dimensional difference between 215/65's and 235/60's; my '69 Z/28 had 235/60 T/A's on it when I bought it, and rubbed both front wheel openings at 12 o'clock when turning; I replaced them with 215/65 T/A's (which are exactly the same size as the original E70-15's) and a) It doesn't rub any more, and b) It looks correct.
                • John M.
                  Infrequent User
                  • February 1, 1985
                  • 26
                  John and Rick, I know that the 235s are too big. I have been researching the 215/65's. My final concern is the 7" rims that I have with the 235s. I'm thinking that I need to find a set of 6" rims to make the 215/65s work. Your input will be appreciated! Rick, what size rims are you running with the 215/65s? Stock ralleys? Or what?
                  • John M.
                    Infrequent User
                    • February 1, 1985
                    • 26
                    Stock ralleys meaning 6" '67 wheels.
                    • Rick A.
                      • July 31, 2002
                      • 2147
                      reproduction k/o's, and believe they are 6" - will need to check paperwork
                      Rick Aleshire
                      • Paul Y.
                        • September 30, 1982
                        • 570
                        I run 225/75 on stock 5.5 rims and no rub on the back with just a bit on the front inside frame when locked. I don't lock them up often on turns and have no fiberglass breaking problems. I like how they handle on mountain passes and stop with the ceramic brakes.
                        It's a good life!
                        • Steven B.
                          • June 30, 1982
                          • 4000
                          Rick, all repro K/O's are 6". You have a very nice '63 by the way!
                          • Rick A.
                            • July 31, 2002
                            • 2147
                            Steve,
                            Thanks for the repro answer and way too kind compliment on "Lady"! Do luv to drive her as much as possible, which is why I have the k/o's with the Michelin radials.
                            Rick Aleshire
