54 license plate bezel fastening - NCRS Discussion Boards
  • Guy M.
    • October 31, 1993
    • 499
    Were the screws installed directly into the fiberglass or can J nuts be slipped over the holes if they are too big like the gas tank cover. The lid is painted now. If J nuts are an option will the bezel look higher than normal? Have you folke run into something like this? Thanks again for the help!!
  • Chris S.
    • December 31, 1999
    • 1064
    Re: 54 licience plate bezel fastening
    the screws go right into the fiberglass
    No room for j nuts
    There is a bezel, the clear plastic shield, and a gasket.
    I always fill the holes when doing my body work - that way - when you go to install the rear screws - they are nice and tight vs wallered out holes......
    • Guy M.
      • October 31, 1993
      • 499
      Thanks a bunch Chris, I appreciate it!
      • Jim L.
        • September 30, 1979
        • 1805
        While the screws went directly into fiberglass when '54s were manufactured, the threads eventually will wear out. Several of the holes on my '54 have worn threads. I have successfully slipped J-nuts into place and I don't see any effect on the fit of the chrome license frame.
        Jim
        • Guy M.
          • October 31, 1993
          • 499
          Thats good food for thought too! Thanks Jim. Guy.
          • Jerry P.
            • September 30, 1989
            • 85
            Small plastic square push-ins work great
            • Troy P.
              • January 31, 1989
              • 1279
              When threads will not be visible you can wrap aluminum foil around the threads to make the screw body fatter without changing the screw head size.
