Smog pump and bracket. What does it belong to - NCRS Discussion Boards
  • Rodney R.
    • July 8, 2013
    • 58
    Front of pump pulley side reads Do not clamp in vise. Metric. On the valve LJ 17063052. 17201. On back side 7834922. Kipp2. Metric. julian date 6160GM/ 2. On the bracket casting number 14018783. At the end of the casting number is a triangle with the letters ADC. In it. What do these parts belong to? They were taken of a 1980 l48 corvette. I don't think they are correct for this car!
  • Michael D.
    • June 30, 1996
    • 536
    Re: Smog pump and bracket. What does it belong to
    The part number for the bracket appears to be correct for 80 and 81 cars based on a Google search. Have you Googled the part number for the pump?
      • 43297
      Rodney------
      I'm out-of-town and away from my references so I can't check the numbers. However, in general the parts and the part numbers look to me like 80-81 Corvette. Could also possibly be from a 1979 but I think 80-81 is more likely.
      • Rodney R.
        • July 8, 2013
        • 58
        I did do a google search and it says they are used on 1980. But the NCRS judging guide listed a different number. I had deductions at a chapter meet for not having the emissions on. So before I put the emissions back on wanted to make sure I have the correc part numbers. Thanks
          • 43297
          Rodney------
          The GM #17063052 valve is uniquely applicable to 1980 with auto transmission.
          GM #14018783 is the correct pump bracket for a 1980 Corvette.
          • Rodney R.
            • July 8, 2013
            • 58
            Thanks Joe greatly appreciated.
