The 65-66 steering shaft - NCRS Discussion Boards
  • Gene M.
    • April 1, 1985
    • 4232
    Anybody have a 63, 64, 65, or 66 steering shaft out of the car to give me a length. I looked in the papers on the Corvette steering columns but they cover only 67 and newer. It shows on page 6 the 67 shaft as 37.57 inches.
    thank you
  • Mike M.
    • May 31, 1974
    • 8400
    Re: The 65-66 steering shaft
    gene: a friend in arizona is repro ing the 63-66 shaft. i lent him an NOS shaft he used as template. i;ll be getting the shaft back shortly and if nobody gives the measurements, remind me in a week or so. mike
    • Tony S.
      NCRS Vice President, Director Region VII & 10
      • April 30, 1981
      • 990
      I'm curious if the standard column has a different length than the tele column since the standard coupler is longer than the tele coupler.
      Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
      Original member of the Kansas City Chapter, est'd 07/11/1982.
      Member: 1965 and 1966 National Judging Teams
      Judging Chairman--Kansas City Chapter.
      Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
      • Page C.
        • February 1, 1979
        • 802
        The standard 1963-66 Corvette shaft is 37 inches overall. The 1965-66 tele column shaft is 35 5/8 min. and 39 3/8 max.
        • Gene M.
          • April 1, 1985
          • 4232
          Page,
          thank you
          • Jim S.
            • August 31, 2001
            • 730
            Not that it means an awful lot but the engineering drawing for the 5694271 1965-66 Corvette telescoping column shows overall steering shaft length:
            Extended 38.665 inches
            Retracted 35.665 inches
            There is a screw 5694806 that is threaded into a weldnut on the steering column jacket. The nose of the screw fits throught the jacket and into a slot in the upper steering column tube and basically controls the amount of stroke of the telescope feature. According to the engineering drawing the stroke is exactly 3.00 inches. Not nearly 4 inches as indicated above. I wonder if the bare steering shaft will telescope on itself by nearly 4 inches whereas the actual steering column steering shaft telescoping distance is only 3 inches.
            Jim
            • Page C.
              • February 1, 1979
              • 802
              Jim,
              The measurement for the tele column was a bare shaft without it being in the tube or without the rod in the upper center. Just the bare shaft full extended and fully retracted
