1970 water pump bolts - NCRS Discussion Boards
  • Phil A.
    • April 30, 1982
    • 121
    Was a 1970 small block equipped with lock washers for the water pump? Thanks in advance. Phil
    • 43221
    Re: 1970 water pump bolts
    Phil-----
    No, it was not. However, there were lockwashers used on the stud which replaced one of the bolts for the generator brace mounting. The lockwashers were not used, though, between the stud and the waterpump, only under the nut that retained the brace.
    • Ron G.
      • December 1, 1984
      • 865
      I can confirm that Mr. Lucia is correct.
      "SOLID LIFTERS MATTER"
