461 heads with no end markings - NCRS Discussion Boards
    • 15696
    Re: 461 heads with no end markings
    Ah, yes. I was talking to someone recently about Brzezinki's work.
    • Loren L.
      • April 30, 1976
      • 4104
      Originally posted by Mike McCagh (14)
      Tom: after removing the camel's humps, take a needle air hammer(like the navy uses to de-rust their ships) and beat the hell out of the casting area where the humps have gone bye-bye. the air hammer will give the surface a rough, sand cast finish. i assume JB Weld or a similar epoxy was used to create the triangle on the top of the rectangle.one can also remove the 6 motor mount bosses on the side of the block to simulate a 348 block. the boos to attach the Z-bar pivot will also need to leave. all of the above is second hand info. regards,mike
      Butter does NOT melt in the good doctor's mouth............
