67 air cleaner element - NCRS Discussion Boards
  • Peter L.
    • May 31, 1983
    • 1930
    Re: 67 air cleaner element
    Ron - GR8 photo. I'd say both are "correct."
    Although there seems to be fewer of the one with the "AC SPARK PLUG A212CW" embossing around, I wouldn't argue if someone showed up with that air cleaner filter on a 67 even though the 1967 TIM&JG shows an example of the filter with the "AC TYPE A212CW" embossing.
    Pete
    • Ronald L.
      • October 18, 2009
      • 3248
      I agree Pete, the lower showed up in 1966 air cleaner assemblies.
      Daniel,
      if you search this forum, there are lots of pictures of the mesh and there isn't a repro out there - that even 'starts' to get close to with correct end caps so what is out there as finished air filters with the top form as per the pic I posted is what was made in 1965,66, or 67.
      Mesh over lap, you have me worried - is there a new rule on this like the new glove box key standard?
      The mesh was made on a manufacturing machine and there were tolerances on overlap.
      Is the filter wrong if I put up a picture with the overlap at .25 -.33 inches total?
      • Howard H.
        Infrequent User
        • January 1, 2005
        • 11
        Here is another example of the A212CW filter. Is this correct for the 67 Corvette?
        • Ronald L.
          • October 18, 2009
          • 3248
          Howard, it matches what we were discussing above.
          • Steve B.
            • March 1, 2002
            • 1191
            Howard, if you have no use for that air filter, I would gladly buy it from you.
            • Gary B.
              • February 1, 1997
              • 7070
              Howard,
              These filters are so rare, they usually have an interesting story to go with them. Does this one?
              Gary
