Wheel question 54 vs 62 nubs - NCRS Discussion Boards
  • Willard M.
    • August 31, 1979
    • 422
    So my 62 wheels have 4 nubs on the inside edge of the wheels to hold the full hubcap or wheel cover. Should my 54 wheels have similar nubs or are they smooth?
  • Mike E.
    • February 28, 1975
    • 5138
    Re: Wheel question 54 vs 62 nubs
    Bill,
    i see no one has jumped in here. My understanding is that the 54's should not have the nubs. Have you looked for dates on a wheel (tire dismounted)?
    Mike
    • Willard M.
      • August 31, 1979
      • 422
      Good to hear from you Mike, and thanks. I have a chapter meet this weekend and Dave Brigham should be there. He should be able to confirm this.
      • Mike M.
        • May 31, 1974
        • 8388
        our 54, which we purchased in 1970, had two numbed wheels and three non-nubed wheels when we acquired it. i can state that without the nubs, full hubcaps have departed the rim on several occasions. i like nubs,whether they come on wheels or chests. mike
        • David B.
          Former NCRS National Judging Chairman
          • March 1, 1985
          • 221
          Bill, nubs first appeared late 54 and 55 model years. Not sure when they first appeared on chests...check with doc...a known expert. Sorry I won't be there this weekend. Dave
          • Chris S.
            • January 1, 2000
            • 1067
            according to GM records and Nolans book - 54 cars did not have the nubs part number 3714202 -
            55 cars did have the nubs and also had the wheel seals - the part number remained the same for 55
            I look at the back of the wheel
            The wheel should be riveted together
            The rivets can be flat or round for 54
            1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
            Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
            1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
            1957 Corvette - FI 3 sp - Black and Silver
            • Troy P.
              • February 1, 1989
              • 1284
              No nubs on unrestored 4273. Don't know about the rest of the series but not knowing personally I'd trust Dave.
              • David B.
                • March 1, 1985
                • 221
                Best info I have is that it was a running change and there is a period when both were used. Dave
                • Troy P.
                  • February 1, 1989
                  • 1284
                  Makes sense to me. Wouldn't be the first time there was a slight error in one of Noland's books. 55 second design washer jar bracket for example. We are all human.
                  • John S.
                    • July 29, 2009
                    • 640
                    i only see one washer jar bracket mentioned by Nolan for a 55 and that is 3113324. blue print for 3113324 appears correct, but the bracket used as a example is probably as close as nolan could get for a bracket out of a car.
                    • Troy P.
                      • February 1, 1989
                      • 1284
                      The photo is not even close. The bracket is shown correctly in the drawing above the photo. It has the square shaped wide ribbed band just like the 54. But the back piece that attaches to the inner fender differs from the 54.
                      I've seen restorers go by the photo and use an incorrect round car bracket.
