67 big block - NCRS Discussion Boards
67 big block
  • Chris L.
    • November 1, 1998
    • 275
    67 big block
    Is 3959512 correct block # for 67 427/400? Thanks in advance.
  • Dick W.
    • 10483
    Re: 67 big block
    Casting date should be mid to late '68, or later, as these blocks started appearing in early December of 1968. Not used in any '67
    Dick Whittington
    • Tim G.
      • March 1, 1990
      • 1424
      Re: 67 big block
      3904351 is the correct casting number for a 1967 427/400 horse motor
      • Cecil L.
        • May 31, 1980
        • 450
        Re: 67 big block
        3959512 is a service small block casting.
        • Dick W.
          • 10483
          Re: 67 big block
          Oops! When I see 512 in the number I am thinking of the 3963512 which is the 427 block
          Dick Whittington
            • 43295
            Re: 67 big block
            Cecil------
            I figure he must mean a 3963512. If so, that block was never originally used on a 1967. It first appeared in late 1969 and was used through 1971. Although it was used in late 1969 for 427 cid engines, it was primarily a 454 block.
            • Jaime G.
              • April 1, 1988
              • 480
              Re: 67 big block
              So what is the correct answer?
              • John C.
                • January 1, 2005
                • 616
                Re: 67 big block
                Tim had it correct, 3904351 is the block used for a 1967 400 HP engine. This block was machined for both 2 and 4 bolt main cap applications. A 400 HP engine should use a 2 bolt main cap block.
