Rebuilding a 59' WCFB Carter Carb. - NCRS Discussion Boards
  • James J.
    Infrequent User
    • March 1, 1985
    • 19
    I am doing a complete rebuild of my WCFB carb. Included with the parts is a small brass needle about half the size of a float needle and a small ball bearing.In the parts breakdown list the ball bearing looks like it's for a starter switch housing that my carb does not have. I thought the small needle was also not for my model carb until I broke it down and soaked each section in carb cleaner and after soaking the middle section, low and behold I find the old small needle in the bottom of the cleaning fluid. My best guess is that it goes beneath the jet and housing assy.-pump. Could anybody confirm the location of this single small needle and can I ignore the little ball bearing....Jim.
  • Philip P.
    • February 28, 2011
    • 558
    Re: Rebuilding a 59' WCFB Carter Carb.
    Jim,
    I have a manual in pdf form that may help if you want me to send it to you.
    Phil
    • James J.
      Infrequent User
      • March 1, 1985
      • 19
      Phil, Thanks for answering my post. If you could e-mail the pdf manual my e-mail address is jims59vette@verizon.net If it's too large for e-mail , let me know how. Your help is greatly appreciated.
