Tires? - NCRS Discussion Boards
Tires?
  • Don W.
    • August 28, 2013
    • 2
    Tires?
    I'm a new member, I hope this isn't a stupid question. I have a 1993, 40th anniversary edition, convertible. I won't to keep it original and would like to have it scored/judged. It needs tires. Does it matter which tires I put on it for judging? If so, what tires were on it originally?
  • Gary C.
    Administrator
    • October 1, 1982
    • 17866
    Re: Tires?
    Don, added the year model to your thread. Thanks for joining NCRS and using the TDB. Gary....
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Guest
      Re: Tires?
      Don,
      First, welcome to the NCRS! Second, if you have not done so as yet, I would suggest you order the "Judging Reference Manual - Eight Edition (JRM)". This will provide you all the knowledge you need on the judging process. Second, I would suggest you also order the 1992-1993 TIM&JG. Both of these can be ordered through NCRS by clicking on NCRS SHOP above. Third, if you have not considered it, I would highly suggest you join a local NCRS chapter where you live. Get out and network with those folks.
      Finally, here are the specs on your 1993 tires and what you need to "strive" and have on your car for judging purposes:
      Front: Goodyear Eagle GSC, P255/40ZR-17 (base), P275/40ZR-17 (ZR-1)
      Rear: Goodyear Eagle GSC, P285/40 ZR-17 (base), P315/35ZR-17 (ZR-1)
      I do NOT believe these tires are currently available from Goodyear, but know folks have bought them from eBabe, etc. Again, the JRM will provide you insight into tires and deductions of the various options available to you.
      • Don W.
        • August 28, 2013
        • 2
        Re: Tires?
        Thanks for the info and I'll order the reference materials you suggested!
          • 43263
          Re: Tires?
          Originally posted by Rick Aleshire (38392)
          Don,
          Rick------
          ... except if the 1993 was also equipped with RPO Z07. In that case, it had P275-40-17 at all four wheels.
            • 43263
            Re: Tires?
            Don-----
            The Goodyear GS-C tires originally used for your car are no longer available and have not been available in quite some time. The only tire which Goodyear currently has available in the sizes to fit your car is the F1 GS-D3. Unfortunately, this tire has a tread pattern VERY unlike the original tires. Nonetheless, it is a Goodyear tire, as-original, so I believe you can garner some judging points on that basis.
            • Kurt G.
              • April 30, 2005
              • 343
              Re: Tires?
              The Goodyear GSC tires were discontinued several years ago, and according to a big tire source in Texas, when they discontinued them Goodyear required all the dealers to return any they had in stock. I found this out after spending countless hours on eBay, google, this and that. I had all but given up, after about 3 months of searching, when I got lucky and found a set of original, non-run flat tires on the Corvette forum. I jumped on them. You can get the run flats from the Tire Rack. You'll take a hit for the run flats, but my guess is that you might have to resort to them, as I almost did. Even at that the hit for the run flats will be less than the hit for Michelins or another brand.
              Kurt Geis
              Chairman, Midway USA Chapter
              Targa Blue 1972, Top Flight and Duntov Award, 2014
              Arctic White 1994, Top Flight, Hrt. of Amer. Reg. 2011
              Arctic White 2013 60th Anniv Special Edition Conv.
              • Tom H.
                • December 1, 1993
                • 3440
                Re: Tires?
                You beat me to it !!
                Rick------
                Tom Hendricks
                Proud Member NCRS #23758
                NCM Founding Member # 1143
                • Paul O.
                  • August 31, 1990
                  • 1716
                  Re: Tires?
                  On the bay right now is a set of rear tires up for buy it now. Supposed to be new never installed set here is the link.
                  • Floyd B.
                    • November 1, 2002
                    • 1050
                    Re: Tires?
                    Those are nice but it sure makes me glad I bought a full set of factory originals for $450 about 4 years ago.
                    "Drive it like you stole it"
                    • Ed N.
                      • May 16, 2010
                      • 1003
                      Re: Tires?
                      Don, message me. I have at least two tires that you can consider.
                      Ed Nieves
                      NCRS #51799
