SEM Interior dye - NCRS Discussion Boards
SEM Interior dye
  • Tom L.
    • October 17, 2006
    • 1439
    SEM Interior dye
    I bought a pair of seat backs at Carlisle that need to be re-dyed. Anyone have a part number for Sem dye that best matches black interior?? Also, the existing dye is spotty, can or should the old dye be removed before re-dying? Thanks!!
  • Gene M.
    • April 1, 1985
    • 4232
    Re: SEM Interior dye
    Lynn,
    Isn't dye more for fabric? The seat backs are plastic. I would suggest a paint designed to adhere to plastic once the old stuff is removed. On my white seat backs I use a semi flat (semi gloss) paint made by Sherwin Williams. They went thru judging just fine. But be sure to keep to just one light as possible coat or else they will look painted.
    • Michael D.
      • June 30, 1996
      • 536
      If you have a SEM dealer near you, take a piece of your existing black and they can match it.
      • Jeff P.
        • 799
        Crylon 1613 semi gloss is perfect for interior black pieces.
        68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
        2014 Arctic White Z51 Vert. (Wifes)
        • Jim S.
          • March 13, 2013
          • 360
          SEM Paints (SEM15013) Color Coat - Landau Black Aerosol
          • Tom R.
            • December 20, 2010
            • 177
            I just refinished my 67 Medium Saddle seat backs using the interior dye products from Corvette America. Lightly scuffing the old finish with Scotchbrite and cleaning the surface with SEM 38373 SEM SOLVE so as to not destroy the molded in grain pattern. Then sprayed two light overlapping coats of interior dye and let dry overnight. Then finished with one coat of Corvette America interior satin clear which mimics the original finish perfectly. I also used this same process to restore and completely re-color (black to Med Saddle) seat belt retractor covers. You can't discern a new cover from a freshly dyed one. I used this procedure for the radio side trim panels, console, interior window trim, halo and fresh air knob.
            • Jeff P.
              • 799
              Sorry for the misspelling , it's Krylon 1613
              • Tom L.
                • October 17, 2006
                • 1439
                I was under the impression that the "Dye" is more like a paint. Is the dye similar to what was used on the plastic parts in the factory? Either way I bought some dye from CA a while ago and it was awful, just wouldn't spray smoothly. Perhaps it was old but I'll use SEM from now on since it's a superrior product.
                Will SEM Paints (SEM15013) Color Coat - Landau Black Aerosol provide the correct gloss on it's own or will a top coat be required as some have indicated? Thanks!!
                • Kurt G.
                  • April 30, 2005
                  • 343
                  I've used the Corvette America products in the past and have been very pleased. Can't tell the difference between the repair section and the original, untouched areas.
                  Kurt Geis
                  Chairman, Midway USA Chapter
                  Targa Blue 1972, Top Flight and Duntov Award, 2014
                  Arctic White 1994, Top Flight, Hrt. of Amer. Reg. 2011
                  Arctic White 2013 60th Anniv Special Edition Conv.
                  • Tom L.
                    • October 17, 2006
                    • 1439
                    Thanks for the unput. I'll be stopping by my SEM dealer soon.
