Re: 1965 Coupe Air conditioning Hot Water Vacuum control swtich info and Questions
Hello Garry,
So are you saying the the long seal I took out of my two valves goes where you put the white heat shrink?
Or that it goes about where you show it in your picture?
IF you put it where you show it in your picture the valve works great, except backwards and passes vacume when the plunger is depresse and is blocked when its released you can tell this because in the non depressed position the .092 necked down area is right between the two ports. No vacuum can pass no matter how long the seal is. I think that people that think it works with one or two o rings in that .092 area are confused about when it does pass vacuum and when it doesn't. This would make thier AC work poorly and their heater not at all, I would think, but several people mentioned they just unhook the vacuum at the water valve in the summer and hook it up in the winter so maybe the orings in the wrong place is the reason why. Ive got my valves to work whith the two pieces of seal on each side of the .092 area as shown in my pictures but I would still like to know how it works if you put it in the stepped down .092 area???
I've ordered a new one and I'm going to take it to work and X ray it and see what's inside. Not sure if I'll be able to see the rubber but maybe I will . I would just take it apart but I bent the shaft on mine taking them apart and so now they don't work in all positions. As you rotate the shaft 360 degrees the valve will get stuck depressed in some positions.
Thanks for your help
Bill
Hello Garry,
Bill
