C-4 oil & coolant - NCRS Discussion Boards
C-4 oil & coolant
    • 15706
    Re: C-4 oil & coolant
    Originally posted by Lyndon Sharpton (12791)
    So should I change out the oil in the 89 corvette to Mobil delvac , I use it in the 71 with L-S 5.?
    Your '89 has a roller cam, but sliding surfaces at the rocker arm. Choosing between S and C-category in this case is nothing to loose sleep over. Either should be satisfactory. I use 15W-40 CJ-4 in all my cars, the newest being a 1991 model. That way I only have to keep one type or oil around.
    • Richard N.
      • July 31, 1975
      • 28
      I've run just about every sort of oil made in my '85. In the last decade it's been all synthetic. Everything has worked. When it comes to the cooling system I use distilled water only.
      Richard Newton
      Car Tech Stuff
        • 43248
        #18
        Originally posted by Richard Newton (678)
        [ATTACH=CONFIG]47683[/ATTACH]
        Richard Newton
        Car Tech Stuff
        Richard------
        Do you mean that you use only distilled water with no ethylene glycol coolant? If so, I definitely don't recommend that. For one thing, you will have absolutely no corrosion protection. For another thing, you won't have the boil-over protection margin that you need, especially for operating conditions that challenge cooling systems.
        • Richard N.
          • July 31, 1975
          • 28
          #19
          You're right about that. I sometimes tell people to run about 25% anti-freeze for that reason. It raises the boiling point. Because mine is a track car it gets the coolant changed about every 2 months. Here's an article did for Vintage Motorsport magazine a few months back. It's all about cooling systems.
          Richard Newton
