62 underbody & engine compartment parts paint - NCRS Discussion Boards
  • Anton S.
    • October 25, 2009
    • 32
    Just finished studying my 1961-62 Corvette Technical Information Manual & Judging Guide and made a spread sheet of all parts that get painted so that I have easy access to this info when restoring my 62. However, I did not find any reference to paint requirements (i.e. gloss, semi-gloss, flat black, etc.) for the following parts; Rear Bumper Brackets, Generator Mounting Bracket, Heater Hose Retainer Strap Bracket (located under generator), Front and Rear Brake Backing Plates, Brake Drums, Upper & Lower "A" Arms, Banjo Housing, Differential Case. Can anyone shed light on the kind of black, if any, goes on these parts???
  • Terry D.
    • May 31, 1987
    • 2696
    Re: 62 underbody & engine compartment parts paint
    Did you try the archives, I think someone else made a similar list. If not it will at least bump your thread back to the front. A list like that would be a nice addition to the Judging Manual. Terry
    • Jerry W.
      • January 27, 2009
      • 588
      ANTON....i SENT YOU A PAINT LIST COPIED FROM A PREVIOUS POST BY EMAIL THRU NCRS FORUM
      LIST IS VERY LONG
      • Anton S.
        • October 25, 2009
        • 32
        Thank you Jerry, this makes life a bit easier. However I notice that a few items do not agree with the NCRS 1961-62 Corvette Technical Information Manual & Judging Guide. I will deal with this ....probably default to NCRS Manual as correct. When I get my list finalized I will share with all.
        • Jerry W.
          • January 27, 2009
          • 588
          Anton....I did not create the list that I sent to you but I think it is generally correct....we used it as a guide when we restored our 62 and did not have any component paint point losses that I can remember at the Texas 2012 Regional
          • Anton S.
            • October 25, 2009
            • 32
            Thanks again Terry, It's good to know that this list worked for you. I will use it along with the NCRS Manual and my 62 parts that are in very good condition since my car was garaged for the 49 years that I have owned it in sunny California.
            • Robert K.
              • July 31, 1984
              • 213
              I would certainly be interested in a list like this.
              • Anton S.
                • October 25, 2009
                • 32
                Robert, Here is the list I received from another member. He used as a guide to restore his '62.. Enjoy;
                Copied from a previous post
                CORVETTE PAINT NOTES
                UNPAINTED:
                - Body Mount Shims
                - Bottom of Body
                - Brakes
                . Brake Line Front Clips
                . Brake Lines & Retainers
                . Brake Shoe Retainer Pin
                . Brass Blocks (including clips)
                . Drums
                . Master Cylinder (can have overspray
                from engine compartment blackout)
                . Vertical Brake Line (could have very slight oversprayfrom engine compartment blackout) . Wheel Cylinder and retainer bolts
                - Clutch Anti-Rattle Spring
                - Door Courtesy Light Switch
                - Drag Link
                - Emergency Brake Cable (from Firewall)
                - Emergency Brake Cables (rear)
                - Firewall Insulation (interior)
                - Front Spindles
                - Gas Pedal Rod (in car interior)
                - Gas Tank
                - Generator Cast Aluminum tach Drive)
                - Heater Box (heater box is installed after enginecompartment blackout. Therefore the box is not painted, and attachment bolts donot have paint)
                - High Beam Floor Switch
                - Motor Mount Bolts (as well a large washer)
                NOTE: (the bolt, nut, and washer receive a stroke ofinspection paint indicating that the engine mount bolts have been torqued down.
                The paint color is a more reddish version of enginecolor)
                - Neutral Safety Switch, Shield, & Mounting Hardware
                - Pittman Arm
                - Rear Axle Pumpkin
                - Rear Spindles
                - Rebound Straps on Rear Axle
                - Rebound Strap Reinforcement Plates
                - Rebound Strap Rivets
                - Steering Gear Housing
                (some examples have this unit painted semi-gloss black)
                - Third Arm Bearing Assembly
                - Tie Rod Ends
                - Tie Rod Straps (as well as nuts and bolts)
                - Tie Rod Support Arms
                - Transmission (Standard); Automatics are painted
                - U-Joint and U-joint Yoke
                - Voltage Regulator mounting Flange
                - Yoke
                PAINTED SEMI-FLAT BLACK:
                - Air Inlets (on either side of grill below headlights)
                - Battery Retainer
                - Engine Compartment
                - Exhaust System
                NOTE: there is a school of thought that the exhaustsystem did not receive a black-out treatment)
                - Front Hood Hinges
                - Generator Housing (rear frame is gloss black:
                front frame and tach drive are unpainted)
                - Hood hardware
                - Radiator Support
                - Starter Motor
                - Underside of hood
                - Wheel Wells
                (painted half way (width wise) during black-out process)
                - Wiper Mounting Plate
                - Wiring Harness Clips
                PAINTED GLOSS BLACK:
                - Clutch & Brake Pedal Assembly
                - Coil
                - Convertible Top bows
                (some say semi-gloss black)
                (rivets are unpainted)
                - Cowl Vent Mechanism
                - Defroster outlets and brackets
                - Emergency Brake Assembly
                (color is gloss black regardless of interior color)
                - Emergency Brake / Hood Release Support under dash(color is gloss black regardless of interior color)
                - Heater Casing
                - Heater Motor
                (could be semi-gloss black)
                - Heater Motor Backing Plate
                - Horn Relay
                - Horns and brackets
                - Radiator
                - Rear License Plate Bracket
                - Starter Relay for Automatics
                - Steering Column Mast
                (slightly dull gloss black)
                - Voltage Regulator
                - Wheels
                PAINTED SEMI-GLOSS BLACK:
                - Clutch Heavy Return Spring
                - Clutch Linkage Bellcrank Assembly
                - Door Window Height Adjusters
                - Engine Components:
                 Coil Support Bracket (Carbureted engines only) Crankcase Ventilation Tube  Crankshaft Pulley  Dip Stick Handle  Dip StickTube  Engine Fan  Flow Through Oil Canister (with white silk screen)  GeneratorForward Adjusting Bracket (no engine color overspray)  Ignition ShieldingBraces  Powerglide dipstick & wire rod handle  Spark Plug Wire RoutingSupports  Water Pump Pulley
                - Frame Chassis:
                 A Arms (upper and lower)
                 Battery Tray, Hold down frame and Heat Shield  Frame Front Cross-member  Front Springs  Front Suspension Assembly  Control ArmSupport Shafts (Lower inner & outer)  Control Arm Support Shafts (Upperinner & outer)  Motor Mount Supports  Radius Rods  Rear Axle Assembly  RearAxle U-bolts  Rear Spring Brace  Rear Springs (bands and liners are unpainted Shock Absorbers  Sway Bars (front and rear)  Sway Bar Bushing Clamps  TieRods  Transmission Mount  Upper Control Arm Support Shafts
                - Heater Motor
                - Inner Door Fiberglass
                - Jack
                - Jack Handle Folding Tool
                - Lug Wrench
                - Master Cylinder
                NOTE: Natural / unpainted is also accepted (receivedengine compartment semi-flat black blackout treatment, on inboard side)
                - Radiator Shroud
                - Seat Frames
                - Steering Column Mast (slightly dull gloss black)
                - Upper Portion of Inner Door Fiberglass
                INTERIOR ITEMS:
                INTERIOR ITEMS (GLOSS RED (or interior color)):
                - Dash End Caps
                - Instrument Cluster Housing (top & bottom)
                - Package Tray
                - Consol
                INTERIOR ITEMS (SEMI-GLOSS RED (or interior color)):
                NOTE: semi-gloss means unbuffed
                - Radio Bezel & Speaker Grill
                - Defroster Bezels
                - Steering Column
                - Turn Signal Housing
                - Steering Wheel Hub
                - Steering Wheel Cover (lower)
                INTERIOR ITEMS ALWAYS GLOSS BLACK
                (regardless of interior color)):
                - Lower Steering Column
                - Parking Brake and Support
                NATURAL ALUMINUM:
                - 2x4 Intake Manifold
                - Fuel Injection Manifold
                - Manual Transmission Bell Housing
                NOTE: will have varying degrees of engine coloroverspray)
                - Fan Clutch
                ARGENT SILVER:
                - Oil Filler Tube
                (on intakes that are natural aluminum)
                CHEVY ENGINE ORANGE:
                - Engine Block and Heads
                - Front Engine Mount
                - Harmonic Balancer
                - Water Pump
                (three bolts orange, stud is cad
                CADIUM PLATED:
                - Bottom Seat Rails
                - Firewall mounted Accelerator Lever Arm
                - Grease Fittings
                CHROME PLATED:
                - Hood Release Handle
                - Parking Brake T Handle
                - Seat Adjusting Handles
                - Window Cranks
                - Inside Door locking levers
                - Instrument Cluster Bezels
                - Grab Bar Bezels
                - Interior Rear View Mirror support
                UNPAINTED:
