Correct 68 L79 Oil Pan - NCRS Discussion Boards
  • Jeff P.
    • 799
    I'm looking for a correct oil pan for my L79. Mine is dented. Is the part number 3956679 ? Are these rare to find ? And last , what would you pay for an NOS . Thank you Jeff .
    68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
    2014 Arctic White Z51 Vert. (Wifes)
  • Dick W.
    • 10483
    Re: Correct 68 L79 Oil Pan
    I believe Keen Parts has a very good reproduction
    Dick Whittington
    • Michael H.
      • January 29, 2008
      • 7477
      Jeff,
      The part number, 3956679 sounds too high, numerically, to be the original part number for 68. That sounds more like a number for 69 or 70.
      I don't remember if there was a physical difference between the 68 and 69 pans. Hopefully, someone that does know will get involved.
      I have a 69 printing of the parts book but I don't have one for 68.
      Edit: I just looked in a parts book dated Nov 1969 and the part number for 63-68 at that time was 3820000.
      • Jeff P.
        • 799
        Thanks guys for your help. I thought that this pan might be earlier . My 68 survivors pan is different. Two small indents on the dip stick side were different than the one long and one short. It has a different bulge around the drain plug.
          • 43290
          Jeff------
          ALL 1968 Corvette small blocks used pan GM #3820000. Oil pan GM #360866 is a 1975+ SERVICE-only oil pan which is very similar to the 3820000 except that the front oil pan gasket radius is 1-3/8" instead of the 1-1/4" of the original pan. The 360866 is long-since discontinued but, as others have mentioned, Keen Parts does make an excellent reproduction of the 3820000.
            • 43290
            Jeff-----
            I can't imagine why. All 1963-74 Corvette small blocks except 63-65 SHP with mechanical lifters, early 1970 LT-1 and 1970-72 ZR-1 used the GM #3820000. I have never noticed even the slightest difference among these oil pans.
            • Michael H.
              • January 29, 2008
              • 7477
              Jeff------
              Joe,
              What is the 3956679 oil pan mentioned in Jeff's post? Is that the first replacement part number for the 3820000? My part number change books only go up to 1970.
                • 43290
                Originally posted by Michael Hanson (4067)
                Joe,
                Michael-----
                As far as I can tell, no oil pan of GM #3956679 ever existed. As a matter of fact, I can't find that any part of GM #3956679 ever existed but if it did, it was never available in SERVICE. Of course, if it was never available in SERVICE it would be pretty tough to come up with that number. The GM #3820000 oil pan was discontinued in December, 1976 and replaced by the GM #360866. The latter was discontinued without supercession in March, 1999.
                There was an "intermediate" replacement for the 3820001 "6 quart" oil pan, though. It was GM #3956670 which replaced the 3820001 in June, 1970. The 3956670 was discontinued in November, 1976 and replaced by the GM #359942 (with the 1-3/8" front seal radius). I do not know how the 3820001 differed from the 3956670. I would expect the only PRODUCTION applications for the 3956670 were early 1970 LT-1 and 1970-72 ZR-1.
                • Michael H.
                  • January 29, 2008
                  • 7477
                  Michael-----
                  Joe,
                  That's what I thought. I couldn't find 3956678 either. I wondered if the number was a typo in post #1 but, as you mention, that is the 6 quart pan, not the correct 5 quart.
                  • Jeff P.
                    • 799
                    3956670 was the number I saw. Sorry for the mixup.
                    • Michael H.
                      • January 29, 2008
                      • 7477
                      Jeff,
                      That would be the part number for the 6 quart pan. Not correct for your 68.
                      • Pat H.
                        • December 1, 1996
                        • 421
                        I have a 69 s/b oil pan that came off a 350/300hp with 2 short ribs and a bulge in the bottom with the drain plug in the rear of the pan. I'm not sure if this is what you're looking for, but I believe this was the original pan form an early 69. It needs to be cleaned and stripped, but it has no dents or damage. If you want a photo, email me at pat.heimrath@rogers.com.
                        • Jeff P.
                          • 799
                          I took a picture of the oil pan in my 68 L79 Survivor. In front of the drain plug there is a crease. Is this stock or did someone hit a rock ect? Thanks, Jeff
                          • Pat H.
                            • December 1, 1996
                            • 421
                            My opinion, it appears to be dented. From my experience and seeing oil pans stamped, I never saw one with a crease at the drain plug, but stranger things have happened
                            • Jeff P.
                              • 799
                              Thanks Pat
                              looks like a call for Joe .
