Looking for AO Smith trim tag Number example(s) - NCRS Discussion Boards
  • Ray G.
    • May 31, 1986
    • 1189
    Looking for end of January 1967 AO Smith trim tag "BODY" number example(s).
    Any help is appreciated.
    Ray
    I hope you dance
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12799
    Re: Looking for AO Smith trim tag Number example(s)
    Have a look a the C2 Registry Picture DB: http://www.c2registry.org/index.php?...ic_status=TRIM
    Rob.
    NCRS Software Developer
    • Ray G.
      • May 31, 1986
      • 1189
      Thanks Rob;
      Looking for more examples.
      Do you have a thought about 1967 AO Smith bodies being used in numerical sequence, or not ?
      I hope you dance
      • Loren L.
        • April 30, 1976
        • 4104
        Ray - '67 Cpe #9283 shows as A-0367; CV #9466 (lst car in Feb '67) shows as A-0721.
        • Ray G.
          • May 31, 1986
          • 1189
          Hello Loren;
          Miss seeing you at Wards place. Be back there in about six weeks.
          Did production practices make it possible to have a VIN lower than #9283 and a AO Smith "BODY" # higher than A-0367 ?
          The Corvette in question is not mine or published, therefore I don't want to publish the actual numbers.
          I hope you dance
          • Larry M.
            • January 1, 1992
            • 2701
            Originally posted by Ray Geiger (9992)
            Hello Loren;
            Coupes and convertibles each had their own unique body number sequence.....both for St Louis and for AOS. Total of four body build sequences.
            My 1967 AOS convertible, body was built March 16, 1967 and has CONVERTIBLE body sequence number # A-2201. My VIN is 194677S114845. This car was built/completed on March 28 at St Louis. If my car was an AOS body COUPE it would of had a different and lower body build number.....probably around A-1100. A lot less coupes were made versus convertibles that year.
            Larry
            • Loren L.
              • April 30, 1976
              • 4104
              Hello Loren;
              CV #9466 carries CV AO Smith body #721; CV #8870 shows as A-0604; CV #8963 carries A-0632. No "first in, first out" rules apply. Clearly AO Smith convertible bodies were moving
              In/Out at a faster rate than AO Smith coupes.
              • Chuck M.
                • February 1, 2002
                • 335
                Hi Ray,
                Our '67 Coupe Vin #8343 shows A-0275. Build date was 1/17/67
                Hope this helps.
                Chuck
                • Ray G.
                  • May 31, 1986
                  • 1189
                  Thank you gentlemen.
                  The numbers you provided give me a great pictures of numbers from the Corvette of the era.
                  I hope you dance
