Flywheel to Pressure Plate Mount Bolts - NCRS Discussion Boards
  • Bob B.
    • March 1, 2003
    • 831
    Hi all,
    Does anyone know if the bolts that mount the clutch pressure plate to the flywheel for a C1 are Grade 5 or Grade 8? I've got 5's, but I'll have to go out to get the 8's.
    Bob
  • Timothy B.
    • April 30, 1983
    • 5198
    Re: Flywheel to Pressure Plate Mount Bolts
    Bob,
    I believe they are grade 5 and have a special shoulder. I think they are still available from GM.
    • Barry H.
      • April 30, 1976
      • 213
      Bob, Clutch pressure plate to flywheel bolts are grade 5, Flywheel to crankshaft bolts are grade 8.
      Barry
      • Michael H.
        • January 29, 2008
        • 7477
        Bob,
        I think Tim is right. The pressure plate to flywheel bolts are unique to that application. The bolts have a slightly larger diameter shoulder in the unthreaded portion. Look in group 0.863 or 0.864 (?) in the parts book.
        They're not unique to Corvette though and should be easy to find. In fact, they may still be available from GM.
        • Jim L.
          • September 30, 1979
          • 1816
          Here's what you want:
          Available from Summit:
          Free Shipping - ARP High Performance Series Pressure Plate Bolt Kits with qualifying orders of $109. Shop Pressure Plate Fasteners at Summit Racing.
          Jim
          • David L.
            • July 31, 1980
            • 3310
            My 1957 & 1963 Chev. parts catalogs list GM # 839756 as the part number for the flywheel bolts (7/16"-20 X 1"). These bolts have 6 radial line segments on the bolt head (grade 8).
            Dave
            • Dick W.
              • 10483
              The bolts are available from sources such as Summit, Speedway Motors, Rock Auto, etc
              Dick Whittington
                Yup - also ARP #130-2201 (pack of 6); pressure plate bolts all have a precision-sized shank below the head to accurately register the PP to the flywheel (bolt on the right in photo below). DO NOT use full-threaded conventional bolts (bolt on left) regardless of its strength rating.
                • Ray K.
                  • July 31, 1985
                  • 375
                  GM #838653 for pressure plate to flywheel attachment bolts.
                  Ray
