'67 Fiberglass cutout for front bumper support - NCRS Discussion Boards
  • John M.
    Infrequent User
    • July 24, 2011
    • 7
    Owned my '67 for 43 years but tree mishap required replacement fiberglass front. NCRS regional judging deducted for "no cutout for front bumper support". I understand this cutout was on '67 only. I want to correct for National Convention. Please . . . member with '67, measure (R or L) cutout - I need 3 numbers: Width (side to side), depth (fwd from back edge of fiberglass) and radius in corners (perhaps see what dia drill bit fits).
    Thanks. We'll be driving to VA starting Sat.
    John (53584)
  • Scott M.
    • January 1, 1996
    • 216
    Re: '67 Fiberglass cutout for front bumper support
    Are you talking about the reliefs in the lower valence for the brackets that run from the frame to the bumpers?
    • Robert K.
      • July 31, 1984
      • 213
      I don't believe that this cutout is a 67 only, but a big block only. I was with Bill Clupper and Mike McCagh at Mike's house when it was discovered that it seem to appear only on BB with virgin glass. My 67 427/390 had it. Years ago Corvette Mike had a no hit sb with it. It made me question the "No Hit" of his car.
      • Ray G.
        • May 31, 1986
        • 1189
        Is this a picture of the cut out ?
        I hope you dance
        • John M.
          Infrequent User
          • July 24, 2011
          • 7
          [ATTACH=CONFIG]47249[/ATTACH]
          Yes, center bumper supports are black hat channels ~ 2 Ft long & approx 8" out from centerline. I'm told fiberglass below grill is notched out on '67 only. I need dimensions of cut out.
          • Keith B.
            • March 7, 2008
            • 928
            Should the cuts be done crudely like the above photo
            • Ray G.
              • May 31, 1986
              • 1189
              Not to long along ago there was a detailed discussion about the C2 Front valance cut outs.
              Can't find it right now, but I think John Hinckley was involved in the posts.
              I hope you dance
              • Charles C.
                • July 25, 2012
                • 37
                Been trying to reply to this thread but my computer keeps locking up when I try to attach pictures.......
                My Feb '67 built 427/390HP A/C car only has a cutout on the passenger side. It's no-hit with original paint so I'm pretty sure it hasn't been messed with (at least with a cursory inspection). The cutout is very neat and follows the recessed area lines.
                If I can figure out the problem with me posting pics maybe you'll get a visual to go along with this info... Charlie
                Charlie C.
                Unrestored faded '67 Coupe Lynndale Blue, Black Leather
                Factory options: A01 C60 G81 J50 K66 L36 M21 N40 QB1 U69
                • Gary B.
                  • February 1, 1997
                  • 7053
                  The cut-out is on my July build date '66 and I have a L79, so it's not '67 only and it's not big block only.
                  Gary
                  • Stephen L.
                    • May 31, 1984
                    • 3162
                    A photo of my 67 BB cutout on the passenger side top view. Dimensions: approximately 2.5" wide at inner side. 3.5" at open side. 3/4" deep. 1/2" dia corners. Edges are NOT raw/rough. Appear to be "molded/finished" edges.
                    • Keith B.
                      • March 7, 2008
                      • 928
                      So it's passenger side only
                        The cutout is on all '66-'67, passenger side only, and looks like the photo below.
                        • Keith B.
                          • March 7, 2008
                          • 928
                          Gary
                          its also on a base engine built in October at with a body made at St. Louis
                          • Henry J.
                            • November 1, 1999
                            • 457
                            My April-built 66 has the cut-out as well. It's an L79.
                            • Joe R.
                              • July 31, 1976
                              • 4551
                              Adding my two cents may not help but the above pictures in some posts don't either. So beware as there are non-original fiberglass in some of the pics. Non-original as it didn't come from GM but from Jim Sermersheim's to be exact!
                              JR
